4x4 front wheel bearing/hub - S-10 Forum
post #1 of 14 Old 01-18-2007, 10:39 PM Thread Starter
( o )( o )'s Avatar
User is: ( o )( o ) is offline
i have a 95 blazer 4x4. i'm pretty sure my front wheel bearing on the driver side is shot.
i have done some searching on this forum and i read my haynes manual.
I'm confused - is there a wheel bearing AND a hub bearing?
if i understand correctly, i can not simply pull the hub and replace the bearing. the book says it is not serviceable, and i have to replace the entire hub. can someone please confirm or deny this?
thanks!
00 Si | 95 Blazer | 02 F350 | 07 MDX
post #2 of 14 Old 01-18-2007, 10:44 PM
ΜΟΛΩΝ ΛΑΒΕ!
1fast4by's Avatar
User is: 1fast4by is offline
Send a message via AIM to 1fast4by
Re: 4x4 front wheel bearing/hub
Yep, Hub bearing, replace the whole thing, Its not hard, takes me a little more than an hr and a half
"The police cannot protect the citizen at this stage of our development, and they cannot even protect themselves in many cases. It is up to the private citizen to protect himself and his family, this is not only acceptable, but mandatory."
-Jeff Cooper
Ban gun free zones!
1fast4by is offline
post #3 of 14 Old 01-18-2007, 11:01 PM Thread Starter
( o )( o )'s Avatar
Cool thanks. I gotta get a deep socket for the axle nut and locate some new hubs.
post #4 of 14 Old 01-22-2007, 03:01 PM
Goran's Avatar
User is: Goran is offline
if yours is a 95 and you've this will be the first change... you're lucky
i've changed 5 of them so far... and mine is a 2000
Cheers
Goran is offline
post #5 of 14 Old 01-22-2007, 07:01 PM
GM junkie
Hoss's Avatar
User is: Hoss is offline
Yup, with an air impact, a 34MM axle nut socket, and a large 3-jaw puller it's pretty easy, just the part is kinda pricey. I think my left one is on it's way out again too
1999 S-10 4x4 - sold
2002 S-10 ZQ8 - sold also
2002 Cavalier - the daily MPG maker
2006 Silverado Z71 ECSB - the new addition
Hoss is offline
post #6 of 14 Old 01-26-2007, 07:59 PM Thread Starter
( o )( o )'s Avatar
thanks guys - more questions now:
*i have read both 34mm and 36mm sockets - which is it? (i suppose i could measure)
*does the 1995 have an ABS sensor? I'm looking at parts and I see some with and some without - also I see some are for 1983-1994 and 1997-2005...so am I looking in the wrong place?
just gotta wait til Feb 9th for my tax return to be deposited befor i order the parts....
post #7 of 14 Old 01-26-2007, 08:21 PM
User is: menotyou is offline
Autozone has 2 different brands in stock. Timken at 215.99 and Valucraft at 165.99. According to their computer programmers there is only one style of hub for 95.
menotyou is offline
post #8 of 14 Old 01-29-2007, 01:56 PM Thread Starter
( o )( o )'s Avatar
[img]http://i8.ebayimg.com/02/i/02/10/b3/96_1_b.JPG[/img]
[img]http://i9.ebayimg.com/03/i/000/79/cd/7c3d_1.JPG[/img]
My 1995 blazer has ABS, but do my front hubs have any electrical connectors?
I am seeing different pictures when I shop. I do not necessary trust part descriptions based on what an eBay seller thinks they have, especially when you see the same part listed, but each listing has different vehicle years...
I just want to make sure ....
(what's up, I can't seem to post an image)
post #9 of 14 Old 02-04-2007, 01:03 AM Thread Starter
( o )( o )'s Avatar
so i picked up a new hub today and an $18 36mm socket. as i removed the suspect hub, ball bearings and chunks of metal began to fall out. "well there's your problem right there" I cleaned it up, greased it up, and installed the new unit. what a night and day difference.
but i noticed new sound of loose metal clicking when i would stop and go and steer. i went home and jacked all 4 wheels off the ground and had my 8year old steer the wheel for me. turns out my new front brake pads are loose. they are snug in terms of the caliper squeezing them in and out, but they are loose in the sense that they slide up and down about 1/4 inch against the rotor within the caliper. both sides do it, is that normal?
post #10 of 14 Old 04-06-2013, 11:00 PM
User is: Bossman62 is offline
Ive been trying to uninstall my hub all day! 3 Jaw Pullers are not working!!! Any suggestions?
post #11 of 14 Old 04-06-2013, 11:19 PM
ΜΟΛΩΝ ΛΑΒΕ!
1fast4by's Avatar
Hammer..
Wow how things have changed... Its about a 15 min operation for me now lol
-Jeff Cooper
Ban gun free zones!
1fast4by is offline
post #12 of 14 Old 04-07-2013, 01:37 AM
Solid Axle MOD
Sonomanclature's Avatar
^^ hammer.
if your replacing it then getting a little violent with it won't make a difference. undot the bolts clear the drop zone, and give it a good whack where the flange attaches to the knuckle. don't pussy foot it, hit it like you mean it.
94 Sonoma Dana44/60 5.7L 5spd
06 Subaru Impreza
post #13 of 14 Old 04-26-2013, 10:13 AM
emmett2455's Avatar
User is: emmett2455 is offline
^ Hit it like you mean it...thats just too funny. You do have to get Medieval on that dang hub bearing for sure!
post #14 of 14 Old 04-26-2013, 02:28 PM
Maybe later.
tytotheler92's Avatar
A little penetrating oil around the CV splines will go a long way also.
2016 Toyota Tacoma TRD Sport 6 speed
1985 S10 Blazer 4WD
