4x4 engine removal help
hey guys i have a 96 blazer with a 4.3 and auto trans. and i need help. i started today on the removal of the engine, and while i was underneath it i was looking at the front diff and its only about a inch away from the pan. so i'm taking a quess and think it need to be dropped. so can someone please help me out on this. any help and some pointers please,
Re: 4x4 engine removal help
i didnt have to move my diff when i swapped myy 4.3 in my 00 jimmy... same truck basically... jsut remove your exhuast manifolds before you pull the motor and wverythign should be fine
You don't have to drop anything. I just finished 2 engine swaps, the first remopving the exhaust manifolds, and the second not removing them. Before you start, use PB Blaster on the body mount bolts, as you WILL need to raise the body. I raised mine enough to put a 2 by 4 in there (Longways). If you have any questions at all, shoot me a PM, and Ill help you out.
Rick |
update... i got it out and put it back in with out dropping the diff. i removed my core support let the engine nose dive and it came right out. was not as hard as i thought it was gonna be.
