sawzall's are cool
4x4 blazer = canyon carver
well i have been tossing around the idea for a while now i want to get a 2 door 2nd gen 4x4 blazer lower it as much as possible and if possible use a bravada transfer case has anyone got any link to the transfer case swap? what is the lowest you can go and still retain all the front 4x4 part? fabing stuff up is not a problem just havent really played with 4x4's before but seems like it could be a fun project so links to parts pics anything really i want to do as much research as possible. i did find a link that had new control arms and removed the torsin bars and used coil overs so that helped
Re: 4x4 blazer = canyon carver
bump b/c im lowering my 4x4 2dr soon. and wheres the coilover conversion link?
Plan Havin MF
I've got a five/six and had to remove the halfshafts because of the high speed humming. So you'll want to go 3-4 in the front if you care about the 4wd.
sawzall's are cool
http://www.raceprovenmotors.com/coilovers.html theres the link and what keeps you from going lower do the halfshafts bind is that the problem does anyone make a high angle halfshaft?
graduated!!!!
not that i have seen, check the sy/ty forums for aftermarket halfshafts.
sawzall's are cool
is the 4x4 components the same on 2nd gens as first gens like control arms shafts ect.
graduated!!!!
i'm not sure, i have been reading that they are the same up till '98 but i am still searching on it
Off Vanning. bbl
They are the same the only difference is sway bar mounts and 98& up spindles have the 2 piston brakes. As far as coil overs they can be bought at turbotime.com, raceprovenmotorsports.com so on and so forth.
Right now I am working on control arms for the coilover swap. rpm has some but they are pricey and not the best design appearance wise. They will be ready around christmas. Also I would use an astro van transfer case since it does not have the smarttrack system and 3/4 in the truck in the sig and has been running fine for 4 plus years. |
sawzall's are cool
you said rpm had some do you have a link to them i could not find them? what would your opinion be for the years to get 95-97 or 98 up its got to be 2 dr and its got to be 4x4? for what i want to build i know things like brakes and suspension are going to be a HUGE part of the build
sawzall's are cool
and what are the causes for broke shafts if lowered to far and what could solve those problems custom made shafts notching frame ect???
Off Vanning. bbl
Off Vanning. bbl
If you go coil oves which are the only way to go to make a true handling truck just set them up so the shaft is parallel to the lower control arm and the control arm should be parallel to the ground. I have an original 88 blazer passenger side cv shaft on my truck and the driver side has been replaced a couple times which I figured out this weekend was caused by the bushings on the diff going bad causing more front to back movement wearing out the joints. You can get a custom shaft made for 100-150 dollars. |
Off Vanning. bbl
Well the 98 and up can come with rear disk brakes and the dual piston front brakes. But they are both pretty equal. depends what you find in good shape. |
bellcranks no more
Off Vanning. bbl
Don't throw that up because you are sick of norcall ss or what ever if you read before saying anything you would see I was speaking about an AWD or 4wd setup since torsion bars are not meant for handling. From switching to coil overs from torsion bars you sve weight and also eliminate a ton of body role.. I have torsion bars in my truck in the sig and what keeps it from truely handling well are the torsion bars since they are providing a ton of body roll. You should do a little reading on syty.net since they are the same suspension designs and frame. |
bellcranks no more
i just like using the smilies ![]() |
Off Vanning. bbl
oh because I agree coil overs are not always the only option but on 4wd they are about the only good option I have seen.
Off Vanning. bbl
I just wanted to bump this thread to talk about half shafts.
After talking to a friend at a drive line shop and a automotive engineer we came to the conclusion the only reason the driver's side cv wears out is due to how it becomes parallel to the ground causing it stress because it is basically to long for the opening. I am having a slighty shorten half shaft made costing about 120 dollars(same as a new one) and going to see if that helps. So hope this helps we shall see. |
