eCkO
3" drop spindles
are the s10 and blazer drop spindles the same
Get on your bike and ride
Re: 3" drop spindles
no, i've learned that the blazer braking system is different and does not allow the s10 spindles to fit...you gotta get the blazer spindles and yes it sucks... their $100 more expensive...
Stock
3" spindle's are nor made anymore. all you can get is 2".
Hates 'know-it-alls'
98+ blazer spindles are different
82-03 s10s/nomas and 83-97 blazer/jimmy spindles are the same and no 3" drop spindles are not made anymore because they were unsafe |
Back in CALI
damn ive never installed 98+ blazer spindles b4 and somone asked me to do it lol.. how is the install different?
i don't think the intall itself is different but the part to instal is different...
as soon as you get the wheel off you will see how simple it is but here goes anyways.
1. remove wheel 2. remove brakes and ziptie somewhere 3. remove tie rod 4. break loose upper ball joint (after removing nut) 5. break loose lower ball join(after removing nut) 6. install new spindle in reverse order 7. get an alignment |
eCkO
thanks ......that sucks that they dont make 3" drop spindles i dont think there unsafe
eCkO
thanks alot evry1... where can i get some for cheap..or not alot
Molon Labe
Buying them used is your best bet for cheap.
The hub is actually a lot easier to install than on a regular s10. 3 bolts from the backside and you're done. |
eCkO
koo im lookin for some right now...
