2nd gen blazer wont shut off when key turns off...
Old 12-04-2008, 06:29 PM   #1
'Stevie Joe'
HighrollerII's Avatar
i got a friend who has an auto 2nd gen blazer and says it wont shut off when he turns the key off but says if u press or release the brake (cant rememebr which) then it will shut off
whats this sound like to yall? if i rememebr correctly i think i remember seeing a thread with a similar problem a good while ago
Old 12-04-2008, 08:04 PM   #2
Giggity Giggity
Woody22's Avatar
Re: 2nd gen blazer wont shut off when key turns off...
I had the same problem with my 96...
Old 12-04-2008, 08:06 PM   #3
workin it !
S10dude's Avatar
so what fixed it?...hummmmmmmmmmmmm?
Old 12-05-2008, 12:23 AM   #4
'Stevie Joe'
heh, yea...what was it?
Old 12-05-2008, 12:59 PM   #5
98Blzr's Avatar
Do any of you have a alarm/remote start?
Old 12-05-2008, 01:07 PM   #6
I Need $
supasoulja's Avatar
that helped out sooooo much
Old 12-05-2008, 01:13 PM   #7
Wannabe Dragger
ExtCab96S_Dime's Avatar
Care to elaborate?
I'm thinking the same thing. If you have a remote start, then check that to see if it's messed up. They will turn off the vehicle if the key is not in the run position and the brake is pressed. If you don't have one, then I have no idea.
Old 12-06-2008, 12:29 AM   #8
Japan bound
nate98blazer's Avatar
my 98 wouldnt turn off when you turn off the key a few years ago, but it also wouldnt turn off when i hit the brake pedal, i had to get out with it in gear with the emergency brake set and pull the engine fuse under the hood, any time i put it in park or neutral the starter would kick in, it turned out to be my ignition switch.
this happened the first week i had the truck, so the dealer fixed it, they tried telling me that the remote starter caused the switch to go bad, and they removed the remote starter along with the factory keyless entry, they never even knew there was a remote starter on it, they gave me the remotes but they both had dead batteries so no one knew what they were for.
Old 12-06-2008, 12:32 AM   #9
Giggity Giggity
Woody22's Avatar
kinda hard to elaborate when i never got the problem fixed. i sold the truck just after it started..lol sorry guys.
Old 12-06-2008, 02:25 AM   #10
forum idiot
orangesonoma's Avatar
does it have remote start?
Page generated in 0.57688 seconds with 31 queries
[Output: 71.85 Kb. compressed to 67.30 Kb. by saving 4.55 Kb. (6.34%)]
