2001 parking brake, and lift kit
I have a 2001 Blazer and the Parking Brake has never worked right...now it doesn't work at all. It is a mfg. defect; Is there a way to fix this???
I have a 2001 Blazer and I would like to run 33x12.50 tires. Who makes a 6" suspension lift??? Last edited by lewman : 11-06-2005 at 05:19 AM. |
Insane Network Engineer
Re: 2001 parking brake, and lift kit
Probably just needs adjustment... Underneath the drivers door is a bracket with an adjustment system... Simply tighten it up until it grabs... If it doesn't grab, pull your rear discs and check to see if the horseshoes slipped the clips that hold it on...
Check Trailmaster or BDS |
Slap my meat on your pita
my PB never worked ive given up on it. and ive got a 6in SL kit on my truck.
