2001 Blazer Gas Mileage Problem
PLEASE HELP! I am trying to find out what the problem is with my 2001 S-10 blazer. I am getting really bad gas milage, i have had it to 2 different shops and they both tell me different things. The 1st one says my timing is off, it is at -15 and they say it should be at 0. He wants to make a bracket for the distrubitor to fake out the computer. The second one say no my timing should be at -15 and that my fuel pump is the problem. they say it is 10lbs low holding fuel pressure, well i bought a new fuel pump, oem from the dealer, and now my mileage is worse( i was geting about 164 mile to a full tank, now i am only getting 140 per full tank). i Have already changed the theromstat, dis a complete tune up and had a fuel injection cleaning done. does any one have any idea what my timing should be set at (i know is is set by the computer, but what is that setting) or have any suggestions on whay i am getting such bad gas milagem and what i can try next??? i cant afford this for 2 much longer
Stock? Yep :-\
Re: 2001 Blazer Gas Mileage Problem
What kind of gas mileage do you get (the Avg Econ on the little overhead display)? I drive a 2001 Blazer too and I'm pretty sure I get 17.1 mpg, all my driving is in town, and I'm a very conservative driver. A few things I've done are replace the fuel filter, replace the airfilter (you dont need to buy any special kit, just buy a new filter) and I hacksawed the snorkel off the front of the air box then hacksawed the bottom of the airbox off.
AMcCann |
I do not have the overhead display as on option on my blazer, but i figure it out every time i fill up and it varies between 9-11 miles per gallon and i just replaced the filters less thsn 6 months ago....when i did a complete tun up
someone said to check my tire pressure. i had on of the guys i work with check it and all my tires were way low. i jave 31x10's on the blazer which call for 50psi cold, when he checked them the front tires had 21psi and the rear tires has 18psi. can that really account for the bad gas mielage?
static
I have a 04 blazer x and im getting around 12-13 mpg which sucks ass. on my 94 s10 i get 24-26 mpg and i drive the crap out of the s10 and always get 400 miles on a tank
HARÍA PIS EN SU EXTREMO
Same Poop,Different Scoop
you change the cap and rotor? what kind of plugs you runnin? 2 or 4 door? any performace problems or just poopy mileage?
according to mitchell on demand it should be 5 degrees below TDC
fuel pressure should be 60-66psi injector resitance should be 11-14 ohms tps sensor output should be 1.0-4.0 volts firing order is 1-6-5-4-3-2 hope that helps |
I have 00 LT 4door I get about 215 to a tank. I think mine sucks, but I have kinda heavy foot
yeah thats a bit low, my 98 4door lt gets about 350 er so to the tank, the lil overhead dealy says im getting like 18-19mpg i have a bit of heavy foot and a ton of ccrap in the back ive also noticed i get better mpg at 60 than i do at 70 or above they seem to have a very tempermental rpm they want to be at for milage
ZR2 member
I was getting 16mpg with Bosch platinum spark plugs. My mechanic sugested going back to stock AC plugs. Says GM specs them for a reason. I did so and mileage increased to 21 mpg highway if I keep it under 70 mph. Hope this helps.
Molon Labe
You're a couple years too late.
The Dreamsicle
thats interesting on the stock plugs. i get a little over 300 miles to the tank with 2wd 5spd. about 22.5mpg hwy.
Molon Labe
You could probably do better than that with a 5 speed. I do with an auto.
The Dreamsicle
ill have to try for better this summer i guess. i just put in a bravada over head console last week. i thought that was really good.
Molon Labe
It's not bad... for an auto, but with a 5 speed you have more potential. A few mods can up your mileage quite a bit.
The Dreamsicle
i have a k&n intake and all new ignition that i put in last fall, what are these mods you speak of.
Molon Labe
Higher flowing muffler, e-fan, underdrive pulleys
EX-REFLECTOR COLLECTOR
wow that is bad...im getting 21mpg in town i have magnaflow exhaust w/2.5" pipe /e-fan/air filter/all synthetic fluids and everysingle filter/ ignition component is new and ive got 143K mi on mine stock pcm /timing
try changing the oxygen sensors...
I did a complete tuneup after 200K and noticed no change in mileage.... i'm thinking about changing the oxy sensors... tuneup was plugs/wires/cap/rotor/pcv valve and airfilter... all was AC Delco except for the airfilter (K&N - Recharge...) |
Has Training Wheels
these and 2.5/2.8 love stock parts.
i got 4 spark plugs from walmart and a fuel filter and air filter on my 2.5l 1st gen 2wd i traded in on my new 00 gmc jimmy 4wd well it was doing just fine, got about 26mpg highway driving mad, and then after the dealership replaced ignition module, i started having problems. computer was bad and still was after i replaced it i guess. drove it at 55mph constant after dealership.. spit and sputtered.. CABOOM spark plug tip disentigrated. put another one in.. same thing, same plug, same cylinder. put some acdelco plugs in and it ran better, and got better mileage by 1-2 ![]() |
