2000 Jimmy Washer fluid problem
I have a 2000 Jimmy I just picked up for a daily. After working some bugs out of it, I only have one more problem. I can not clean my damn windows.
![]() I have checked and found where there is suppose to be a fuse for the washer motor under the hood, but there is no prongs for the fuse in its place. I have also checked the motor and it is not getting any power when activated. Any suggestions?? |
Re: 2000 Jimmy Washer fluid problem
Start tracing the wires from the pump. There are two fused locations on those and the fuse may be under the hood or it could be in the dash next to the door. I know you said that the location is labeled but I have seen fuses in places where there shouldn't be any. (even on my new 04 Sierra)
Can you run a jumper wire from the battery to the pump to test and make sure it works? |
flamed up 4.3
i'm having a similar problem with my s10 xtreme..
my wipers go and i can hear the pump running, but no fluid comes out... it worked for a bit about a week ago, and then quit again. wtf? |
