2000 Jimmy turn signal bulb repalcement
Old 03-15-2005, 01:34 PM   #1
2000 Jimmy here. I had a front turn signal go out & thought I'd swap the bad bulb out in the parking lot of the auto parts store. To my suprise, it looks like I need to take the whole headlight assembly out to access the bulbs. It looks like the assembly is held in by two hex type pins mounted at 90* angles. Am I even close? Is their an easier way of replacing a burnt out turn signal bulb on these cars?
Old 03-16-2005, 12:48 AM   #2
dropped99jimmy's Avatar
Re: 2000 Jimmy turn signal bulb repalcement
nope there are slider tabs on the inside of the radiator support closest to the eng compart ment and the headlight falls out really easy to do those screw your seeing are the set screws ofr the angle of the lense
Old 03-20-2005, 09:48 AM   #3
V8 Member
the_dubster98's Avatar
Old 04-30-2005, 05:15 PM   #4
Vsandme's Avatar
easy to fall out maybe but a pain to reinstall, I recently replaced my entire headlight assembly and the tabs that hold it arent in the radiator...back of assembly :-D
Page generated in 0.57244 seconds with 31 queries
[Output: 50.35 Kb. compressed to 48.01 Kb. by saving 2.33 Kb. (4.64%)]
