2000 Blazer Driver Temp Display Issue.
Old 08-17-2008, 01:54 PM   #1
Exclamation 2000 Blazer Driver Temp Display Issue.
Hello all. New to the group and I also own a 95 S10 PU..
But first and foremost.....
My wifes 2000 Blazer with the Driver Information Compass/Temp display has been acting goofy. The compass works fine but the Temp display reads OC. I already replaced the outside temp sensor loacted behind the grill (I was told that this might cause this issue) .. this in fact did NOT fix it. If it really cool outside it will show a temp of 30 degrees colder then it really is.
If anyone has any ideas I would appreciate the help.
Old 08-17-2008, 03:30 PM   #2
forum idiot
orangesonoma's Avatar
Re: 2000 Blazer Driver Temp Display Issue.
never seen that
Old 08-17-2008, 06:37 PM   #3
Overhead Console Expert
raven2510's Avatar
either you got the wrong temp sensor from the wrong yr....or check the ground
im betting you have the sensor from the earlier yr console
you need this part #....GM part number 15971127
Tad
Old 08-18-2008, 09:05 PM   #4
Well I got the part directly from GM and I don't recall the part number but I am hoping it was correct.
Tad
Old 08-19-2008, 06:38 AM   #5
ZQ8 Blazer
ZQ8 Blazer's Avatar
Mines been the same way since I bought it, I also replaced the temp sensor and that didn't fix mine either, although I bought a used one. I've asked your same question on a bunch of different forums and no one has ever heard of it, let me know if you get it fixed
Old 08-22-2008, 11:10 PM   #6
Build them right....Mod
philntx's Avatar
Typically OC indicates (Open Circuit) or a bad temp sensor.
To verify, un-plug the sensor, you'll generate an OC on the console.
Old 08-22-2008, 11:42 PM   #7
The Dreamsicle
cpolaris502's Avatar
is it a factory console? did the new part look identical to the old one?
i put a console in my truck over the winter and there are 2 different types of sensors, once will read about 10-15* hotter than it really is.
Old 08-22-2008, 11:47 PM   #8
ZQ8 Blazer
ZQ8 Blazer's Avatar
mine is the factory one, they looked identical. Even if the temp was off why would it say OC? I need to take it down and hook a ground into it to see if that's the problem.
Old 08-23-2008, 02:09 PM   #9
philntx's Avatar
OC = open circuit
You need to trace your wires/grounds/connections/ etc
Old 08-23-2008, 02:31 PM   #10
The Dreamsicle
you shouldnt need to take the console down to add the ground, you can ground it right by the sensor, just figure out which wire goes to the console and which one is ground.
Old 08-23-2008, 07:55 PM   #11
ZQ8 Blazer
ZQ8 Blazer's Avatar
OC = open circuit
sorry didn't read your post, you sir are god, I've been trying to find out what that means for a year now!
ok I didn't know if the open circuit could be at the temp sensor or the display. I'll try it at the temp sensor 1st.
Old 08-24-2008, 01:24 AM   #12
ZQ8 Blazer
ZQ8 Blazer's Avatar
thanks guys, turns out there is a plug for it on the drivers fender an two wires were pulled out of it, I couldn't find the plug cause it was down in a fender hole, but I fixed it and it works perfect now 8)
Old 08-25-2008, 01:14 PM   #13
philntx's Avatar
Glad to help!
Old 08-25-2008, 03:32 PM   #14
Mine always reads 58* at the console unit above your head. What was it again I should look for again?
Old 08-25-2008, 08:43 PM   #15
ZQ8 Blazer
ZQ8 Blazer's Avatar
I have no clue except maybe it could be something wrong with the temp sensor itself.
Page generated in 0.59326 seconds with 31 queries
[Output: 88.86 Kb. compressed to 82.56 Kb. by saving 6.30 Kb. (7.09%)]
