I'm probably drunk.
20, 19 or 18"rims on a blazer
i know s10's have a different ride height and sidewall size so im asking just you blazer guys
if i get 20" rims what size tire would be the same size diameter as a factory tire? same thing for 18's and 19's also.... if i get 20's with a medium to low sidewall height, will a 2-3 drop rub? what about a 3-4 drop? i dont know much about tires and rims, but im trying to learn if you could, please tell me what you are running if its 18" or bigger rim size, tire, rim offset, if you have adapters....blah blah blah thanks guys, dave |
Location: Lapeer / Midland, Michigan User is: OffLine |
Re: 20, 19 or 18"rims on a blazer
0 rubbing with my 20"s... i have a 2/3 drop also.
they are 20x9 with 245/40/20 tires http://img.s10forum.com/My-Blazer-X/aat.sized.jpg |
what i did was found a tire calc and used a little trial and error till i found the size(s) that i wanted. go to this site: http://www.dakota-truck.net/TIRECALC/tirecalc.html and go down to the left. set Tire A as your stock tire and then whatever you can find in a 20/19/18 that is a popular size for Tire B, select the bullet that says Compare Tire A to Tire B and see how close a match it is and then you can go from there.
I'm probably drunk.
appreciate it
and digital, is that a 2/3 on top of the extreme suspension? |
Yup
I'm probably drunk.
dude i just saw you EXACT same rims today on a 745 bmw
they werent chrome on the spoked part though, they were gunmetal |
HATEKILLDESTROY
i rub a little bit but thats just the tire on the frame. im rolling 20x8.5 with a 245/40/20 tire and a 2/3 drop. looks good and rides better then a 35 series tire.
I dont have any rubbing on my 00 4x4 blazer and Im running a 19x8 with 245-45-19. No rubbing even at full turn.
'01 Blazer
3/3 drop 245/40/18s 25.7" diameter No rub at all. 235/75/15s 28.9" diameter A little rub at full turn. Here's a couple pics, ![]() ![]() |
I'm probably drunk.
dude you have my blazer, with rims and a drop
![]() it looks good btw |
