Moderator
2 door 2wd stock blazer owners pull out the tape measure
whoever has a STOCK suspension/tire height 2 door(if it differs from a 4door) 2wd blazer, can you please measure somethings for me..
the height from the ground, to the center of the fenderwell lip(front and rear) and then the distance between the middle of the wheel to the fenderwell lip.. my blazer had 235/70/15's on it factory.. im guessing all do. hopefully. thanks |
Moderator
Re: 2 door 2wd stock blazer owners pull out the tape measure
so what are you doing now? going back to stock height?
I'm actually wondering the same thing. I had the measurements from when it was dropped 3/3 but I have no clue what I did with them. I would like to see the same measurements for the rear also.
i have 4dr measurements but it's not like that'll do you any good.
Moderator
The Dreamsicle
i think i read that either 2wd's or 2drs are 1 inch taller than a 4x4 or 4dr. i dont remember which one, i think its the 2wd's.
Registered (Ab) User
I have 30 1/8" front and 32 1/2" rear. All stock 4 dr w/ 235 70 X15 Michelin LTX M/S @ 35 psi.
HTH. |
mabey if i get bored ill go look for one just sitting outside and go mesure it but there pretty hard to find around these parts lol
well i found my stock measurements for the 4dr.
front driver - 33 1/8" front pass - 32 7/8" rear driver - 32 3/4" rear pass - 32 3/4" i think i had a half tank of gas when i took them. |
Maybe this will help....I have a Stock 99 2DR 2WD Blazer...Tire size of 235/70R15...These were taken on my driveway that I would say is pretty close to level...The measurements are taken from the ground to the top of the wheelwell and then from the center of wheel to the top of the wheelwell...
Driver Front 31 3/4" and 18 1/2" Driver Rear 32 3/4" and 19" Passenger Front 31 3/4" and 18 3/4" Passenger Rear 33 1/4" and 20 1/4" |
The Dreamsicle
on mine, from the ground to the fender lip i have 22" all around. from the measurements above it looks like my truck has a 12" drop.
Moderator
sweet, thanks for all the measurements! i wanted them so i can see how much drop exactly i have.
The Dreamsicle
oops, mine would be dropped 10" not 12 like i said earlier.
