1999 Blazer Wheel Bearing Replacement
I got a call from my brother last night, he needs help changing a front 4x4 wheel bearing in is '99 Blazer. I've never worked on these model Blazers, any help, tips or diagrams to ease the pain? I'm one of those "First On Race Day" guys so I'm not too familiar with his vehicle but I want to help my brother fix it right. Without seeing the front rotor area yet, I think I'll need a 36MM deep socket according to some other posts to remove a spindle nut? What kind of time is this job per side?
Thanks, Doug |
Re: 1999 Blazer Wheel Bearing Replacement
I had never done one before and I changed both of them on my Jimmy, working alone, in about 4-5 hours.
Here's pictures when finished. Passenger side: http://images9.fotki.com/v184/photos...M003438-vi.jpg http://images9.fotki.com/v183/photos...M003439-vi.jpg Driver's side: http://images9.fotki.com/v185/photos...M003440-vi.jpg http://images9.fotki.com/v179/photos...M003441-vi.jpg Steve |
Is there a step by step procedure on the internet for this? Are there any special tools required other than the 36mm socket?
Here's a good write-up on ZR2.com http://forum.zr2.com/ubb/noncgi/ulti...c;f=3;t=002320 |
www.myspace.com/MINTSICK
how can you determine a bad wheel bearing. My wheels make a "rapping" noise when it drives, gets louder as you go faster and also louder when you make turns
A bad wheel bearing will make a growl sound, acompanied by a vibration. It will become worse as speeds increase. The most obvious characteristic of a failing wheel bearing is that the sound and vibration become worse while turning in one direction and seem to disappear while turning in the other direction. (Unless both sides are bad, but usually the passenger side goes out long before the drivers side.) If the symptoms get worse while turning left and get better while turning right, that would indicate that passenger side is bad. Obversely, if the symptoms get worse while turning right and get better while turning left, that would indicate that the driver side is bad.
If you guys don't want to spend the $20 for the 36mm socket, AutoZone has them in their Loan-a-Tool program. You will probably want to get a puller as well, it can be quite difficult to get the axle out of the hub.
BTW The Haynes manual lists the wrong torque spec, the 36mm drive axle nut needs to be torqued to 180 ft/lbs. |
nice, thanks dude, thats what mine sounds like, worse at higher speeds and worse when turning, how much are they to replace and if i brought it to a shop w\hat do you think it'd cost?
It isn't that hard of a job. It would be a lot cheaper to do it yourself. The hub assemblies will cost about $140 each at a local parts store, up to about $300 each at the dealer. If you have a shop do it you need to add 10% - 20% to the price of parts and figure about 5 -6 hours at their labor rate. (If you do it yourself, it will probably take 2 - 2 1/2 hours to do the first one and about an hour to do the second one.)
Almost forgot: You will also need an 18mm wrench for the hub bolts. |
Where did you get the 180 from? The GM service manual says 103. |
180 ft/lbs for 95 - 98 103 ft/lbs for 99+ This seemed odd because 98 has the exact same front end parts as the 99+, so I thought that it should have the same torque specs. rlith said that he bought a hub for a 01 and it had a tag on it that said 180ft/lbs. To clear it up rlith went to his local Chevy dealer and had them look it up. Here's a quote from his post "According to the manuals (up to 97) and the pc read outs (98 to current) the torque is indeed 180 ft pounds through all years. He and another tech went on about how a lot of times the torque specs (and some info) is wrong in the haynes/chilton's manuals for that type of thing. They also said, 160 is acceptable and they are actually capable of handling up to 200 without issue. They usually impact wrench them on instead of using a torque wrench... But they said 103 ft pounds is way to low though it won't necessarily hurt the bearing in the short term but it should be tightened up..." Last edited by Blazee : 07-24-2005 at 12:10 PM. |
my friend got his wheel bearings done on his truck, $240 for both sides, total
Interesting. My 2001 GM service manual states 103. This is the GM manual, not Chilton, Haynes etc. |
It was probably a mistake when the GM manuals were first printed. That would explain why the Haynes manuals are wrong, too. The PC read outs that the dealer showed rlith will be more up to date.
I ran into the same problem with the lower ball joints on my Impala. The original manuals said that they should be torqued to 125 ft/lbs and were later revised to the proper 83 ft/lbs. |
Canadian Dictatorship
I did mine on my truck about six months ago.....
I didn't care for the new prices on the hub so I found a donor 02 Jimmy hub for 70 bucks. ![]() |
