1999 blazer 4.3 timing
Old 07-24-2007, 10:21 AM   #1
What is timing supposed to be at idle aprox 650 rpm on 1999 4.3 2door Blazer LS auto 4x4.
I put in new distributor (used 2005 distributor) is it possible to be a tooth off TDC or will that trigger MIL. Starts good, idles ok but has a miss under hard acceleration just off the line. If I accelerate slowly no miss. New plugs.wires, rotor, coil (Cap is off 2005) Would the igniton control modual be faulty maybe? Blazer was missing before I put in 2005 distributor I replaced distributor because ithe screw holes for the cap were cracked someone over torqued them maybe. I have only had it a year.
No codes, but MAF is reading 0.000 on scan tool which reads in lb/min. I read supposed to be 5gm/sec to 7gm/sec at idle so does that mean my MAF is faulty if the scan tool reads MAF 0.000 at idle or any other rpm.
I took the MAF off and sprayed with carb cleaner but no difference.
thanks for help
Old 07-24-2007, 01:34 PM   #2
Re: 1999 blazer 4.3 timing
sorry about double post
Page generated in 0.55519 seconds with 31 queries
[Output: 43.35 Kb. compressed to 41.74 Kb. by saving 1.61 Kb. (3.71%)]
