1996 Blazer will not start, no spark
I have a 1996 S-10 Blazer 4x4 with about 180k miles on it. Everything was running fine until I had to replace the alternator due to a bad bearing. I bought a remanufactured one from AutoZone and installed it along with a new belt tensioner. Now my Blazer won’t start. It does turn over and I can hear the fuel pump turn on but it will not run. I checked for spark using a timing light and found that sometimes 2 or 3 plugs don’t spark. I checked for spark on the coil wire and it seems to be working fine. Could I have fried the ignition module/computer when I installed the new alternator? Could it be a bad alternator?
Thanks for the help. |
Re: 1996 Blazer will not start, no spark
I checked the crank sensor and sensor wire and everything looks ok but I do not know how to test it. I just replaced the distributor cap and rotor but my Blazer still doesn't run. When I check for spark between the coil and the distributor and it seems to spark just fine. But when I check for spark between the distributor and the spark plug, sometimes there is no spark. How do I test the crank sensor? Does anyone have any suggestions?
Thanks for your help. ![]() |
CHANGE YOUR EMAIL ADDRESS
alternator will not prevent the engine from running. All it does is charge the battery. Is it sparking when its supposed to (timing) ? Ive had a v6 run rough minus 2-3 cylinders, so a couple not firing wont keep it from running at all. And it ran fine right before you changed the alternator??
did you plug everything back in?
I don’t know how or why but it runs now. I let it sit in my garage for a couple of days and it started right up. I didn’t do anything to it. Maybe moisture got into the distributor or something. Or maybe it just healed itself.
