16X8 wheels & 255/65/16 Tires on Jimmy, rub issues?
I'm probably going to go with a 16x8" wheel and 255/65/16 tires on my stock height 00 4x4 Jimmy. I just wanted to check and see if anyone knows of any rub problems running the wider tire in the front?
Thanks, Steve |
I GOT BLING-BLING
Re: 16X8 wheels & 255/65/16 Tires on Jimmy, rub issues?
I've got 255/55/18s on my blazer, that is dropped about 2.5" and they don't rub
Thanks, I should be ok then.
Steve |
18 x 8 or 18 x 8.5 or 18 x 9 and you say you got a 2.5 lowering kit do you have any pics Last edited by aztecaking100 : 06-09-2004 at 01:52 PM. |
Just wanted to say that 255/65/16s will rub in the front! I'm switching the fronts to 235/70/16 to hopefully solve the rub problem.
![]() ![]() Steve |
say Dantheman are you sure 100% your tires don't rubb Stevel said his were rubbing are you sure you don't have 235/55/18
say stevel did the switch solve the problem
They still rub on the flaps but not as bad. To be honest, I think the stock tires would probably rub on these flaps. I went ahead and took the flaps off tonight. I'm trying to find a smaller flap or something to use in their place. So for now, with the flaps gone I "should" have ZERO rub issues. ![]() |
