KentuckyMinis.com
01 Blazer, Gas gauge broke?
Bought a 01 blazer, gas gauge constantly reads E and says Low fuel. It will drive for about 20-30 Miles then die, fuel pump won't kick on nothing. But if you put about 2 gallons of gas in it, it will fire right up.
MY question is, is the sending unit and fuel pump all 1 assembly. I'm about to replace it and I see the best 1 at autozone is $300+ which is no biggie. But I'm trying to fix this problem all in 1 shot. Thanks guys Nick |
Re: 01 Blazer, Gas gauge broke?
Yes, The sender unit and fuel pump come together as a unit. I heard some where that there is suppose to be a kit to just fix the sender part, but I never could find one, so I just went ahead and replaced the whole thing.
same here when I first bought my truck the gas gauge didnt work right either. about a year later my fuel pump crapped out. comes together
blazer is dunnnnnnnnn!
dont buy the one from autozone. h/o and ill find you a link to a cheaper gm one online
KentuckyMinis.com
Car lot ended up splitting the pump with me, everything is beautiful now. Fuel gauge works perfect.
KentuckyMinis.com
So that problem is fixed, but when I bought the blazer the cluster plastic was cracked. How would I go about fixing this, I seen it looked to be glued down. So I would have to order a direct replacement thats already disassembled, any help would be appreciated. Thanks guys.
get one from s10warehouse on ebay. theyre like $10-15. you pull the bezel off, then the cluster out, and it clips on the back. the clear plastic and black part are one piece
*edit - they musta went up in price. you can find one cheaper, but here's what i was taking about: Last edited by purplepassion : 08-09-2009 at 03:31 PM. |
KentuckyMinis.com
Thanks chief, exactly what I was looking for. I was trying to get your number earlier but couldn't. I bought this blazer off the car lot cheap with knowing a couple of the problems, the squeaking breaks being 1 of them. What do you guys/brian make of this? http://s33.photobucket.com/albums/d5...t=DSCN0887.flv |
