'00 blazer drivers front window issue
Old 07-04-2006, 10:23 PM   #1
Everyone,
The drivers front window of my '00 blazer lt 4x4 has quit working. When we push down the switch nothing happens... If we hold it down, the switch itself clicks. I tested the switch and it is appling current when held in the down position and the up position. I belive it is the brown and light brown wires in the harness. I unhooked the harness and applied power directly to the brown and light brown wires and nothing happened.
Any ideas?
Old 07-05-2006, 06:14 PM   #2
Re: '00 blazer drivers front window issue
take off the door panel and check if you get power at the window motor. If not, then it's wiring or a relay... If you do, then it's a faulty motor.
Old 07-18-2006, 11:20 PM   #3
i have a similair problem and mine works sometimes and other times it doesn't, if i slam the door it will work again. But i think i have som pinched wires or something... and mines an 02 Blazer...
Old 07-25-2006, 09:22 AM   #4
Doughboy
LO XTRM's Avatar
Quote: Originally Posted by symbasden
Everyone,
Any ideas?
check to see if you are getting power to the window motor, I have a o2 blazer extreme and have replaced both motors.
Page generated in 0.55639 seconds with 31 queries
[Output: 50.20 Kb. compressed to 47.89 Kb. by saving 2.31 Kb. (4.61%)]
