Windshield seal leaking... how to fix? - S-10 Forum
post #1 of 16 Old 05-19-2008, 02:33 AM Thread Starter
User is: HenryG is offline
So I brought the truck to a self wash place and the pressure from the sprayer lifted part of the seal on the windshield and caused a few drops of water to come through.
It looks like the windshield was replaced before and the seal itself was not put on that great.
What kind of sealant should I buy? I'm going to peel back parts of the seal ( or all of it ) and try to seal it all back up before it starts raining again on tuesday.
Any advise would be great.
-Henry
HenryG is offline
post #2 of 16 Old 05-19-2008, 04:20 AM
jarrodh's Avatar
User is: jarrodh is offline
Re: Windshield seal leaking... how to fix?
actually the rubber strip around the utside of the glass doesnt seal it, theres actually a urethane bed that seals the glass to the pinchweld.....so sealing betweeen the rubber strip and the a-pillar most likey wont do anything..
i used to do glass...
if you have access to a air compressor, get someone to blow the air around the edge of the windsheild from the inside, and put some soapy water on the outside, and where you see bubles is most likely the leak..
get poly urethane sealer, i think most parts stores should have it... comes in a tube for a caulking gun..by the way, it works best when the tube is hot.....
also where is the water comin in, it may be somethin else.. lie in the cowl vent or the kick panel vents..
s10#1
84 s10 ext cab. full roller 355,aluminum 195cc heads,,XR276HR comp cam,1.5/1.6 roller rockers,750cfm holley, 31 spline ford 9" with 4.11's and eaton locker... Dynoed, 331tq @ 3800rpm, at the wheels..
s10#2
91 reg cab shrt box.. being built into a pavement oval stock car..
jarrodh is offline
post #3 of 16 Old 05-19-2008, 05:27 AM
User is: MadMikeZ28 is offline
You might just want to find out how much a good glass shop will do it for. The hacks will just pile urethane in there and may never seal the leak then there is a mess. The urethane is also thick and does not flow. A good glass shop will have a liquid urethane that is used to seal leaks. It flows into the gaps and alows the air to be pushed out thus filling the area.
If I acted like some of the people here do and ran to someone when ever my feelings were hurt I would have been called a sissy and then ridiculed for that as well. I suppose I just grew up in a time when we were all tougher and turned out to be men and women instead of staying crying children.
post #4 of 16 Old 05-19-2008, 03:57 PM Thread Starter
I wish I had brought the truck to work to get a better idea on what you are talking about.
What if I were to peel back the seal and fill it with some poly urethane sealer? I'm not familiar with windshields at all so I don't know exactly what you're talking about. How will water still get into the cab if that seal is completely sealed up?
At the carwash I had a few drips coming from above the drivers side sunvisor.
Also, I noticed a trickle of water that has come down the drivers side footwell on the left and has now soaked the carpet.
I have a small list of things to fix on this truck but I really love it so far.
HenryG is offline
post #5 of 16 Old 05-19-2008, 04:06 PM Thread Starter
I've had cracks repaired before but I've never had anything major done to the windshield on any vehicle I've owned so far. About how much should something like this cost? I'll see what I can do as a temporary fix but I may need to have someone professional fix it.
HenryG is offline
post #6 of 16 Old 05-19-2008, 04:06 PM
jarrodh's Avatar
we had cars brand new right off the lot that have factory leaks at the body seams in the cowl, and i mean big open holes.., the new mustangs around here were bad for that..
over the years,the urathane gets hard, and as the truck flex's and what not it may make a smal pinhole,and the high presure may have just found it and opened it up..
id recoment takin it to a glass shop and have them do it, itll end up lookin cleaner after its all done.. and as for the drip on the foot well, check the cowl drains downt he side of the cab.. take off the cowl, and get some wire and try to fish it down there, my truck had the same problem..
s10#1
s10#2
jarrodh is offline
post #7 of 16 Old 05-20-2008, 01:54 AM
Odogg81Malibu's Avatar
User is: Odogg81Malibu is offline
Even having a new windshield put in is about $150 around here. A leak repair prbly wouldn't be too much.
  • 1993 Sonoma SLE,4.3z, D.D. foemaster,K&N,62,000mi.,2/3 drop
  • 1999 Blazer LS 4x4 Flowmaster,18"Eagle Alloys(family truck)
  • 1981 Malibu 2 door 355 soon
post #8 of 16 Old 05-20-2008, 07:49 PM Thread Starter
cowl come off with a few bolts? I'll take a look at it when I get home. It rained today so last night I sealed off the window seal really really well with electrical tape ( yes, it's pretty ghetto ), but I wanted to eliminate the seal as the problem. There is no way any water got underneath all that tape so if I find water in there today I'll suspect that it's from the cowl.
Hopefully it works and I didn't waste a roll of tape.
HenryG is offline
post #9 of 16 Old 05-20-2008, 08:07 PM
trailwart's Avatar
User is: trailwart is offline
a mobile glass company around me only charges 40. to come pull and install winshield.
post #10 of 16 Old 05-21-2008, 12:49 AM
This is including the cost of the new windshield
post #11 of 16 Old 11-08-2010, 05:42 AM
User is: Ryanrrn is offline
I did the Windshield replacement with the worthy price and also got excellent service from Bulls Eye.
Ryanrrn is offline
post #12 of 16 Old 04-13-2011, 11:18 PM
lazer's Avatar
User is: lazer is offline
i need to pull up this thread, if i pull off the plastic trim around the windshield i need to fix some small rust spots where the leaks around the window. should i just use a type of body filler i dont know what it looks like yet so id like to pull off the trim and fill what i can, right?
91' GMC Jimmy 4.3
cloned the 89
89' s10 blazer 2dr auto 4.3l 4x4
RIP Sandy Victim
lazer is offline
post #13 of 16 Old 04-14-2011, 11:27 AM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
In alot of cases, the reason for leaks is rust. The pinchweld (the area the windsheild fits into) rusts under the urethane and creates a leak. If you are planning to keep the truck for a long time, the way to fix the rust (almost permanently) is to pull the wshield - there are 2 specialized tools to do this, one is an L shaped blade on a handle with a pull handle attached to it, the other is a spade blade which is very expensive. Next - sand blast all rust, epoxy prime the bare metal, if there are any holes, fill them with JB Weld epoxy putty, sand the putty smooth. JB Weld is bullet proof. If you are careful, you can put the putty on smoothly. The next step is to use pinchweld primer - bonding primer for the urethane that the sheild sits on. Urethane comes in tubes for caulk guns. You have to cut a big 'V' in the applicator tube to get the right shape for the applied urethane. It looks like an upside down V. As the windsheild is set, it pushes the point of the V toward the pinchweld and spreads the urethane for a good seal. It helps to have 2 people to set the wsheild unless you have a big suction cup with a handle on it. On S10s, there is a rubber widsheild molding. This only fills the space between the wsheild and body. I glue this to the wsheild before I install the glass. You can buy it in a roll or precut. It makes the job alot cleaner if you put the strip on beofre installing the glass. BTW, wear those mechanic's vinyl gloves. The materials you use for this job will not come off. It will have to wear off of your hands.
I guess this is more than you expected, but at least you know what's involved. It's really not difficult, the biggest PIA is sandblasting the rust areas. Sandblasting is the only real way to get all of the rust out since it gets into the rust holes. Grinding only gets surface rust off. If there is any rust left, it WILL come back.
After all of this, you can do a quick fix with clear RTV silicone caulk. Seal the wsheild molding all the way around. I put a really thin bead on each side of the molding and smooth it with my finger after dipping it in water (finger). Once the silicone dries, you don't notice it. You can also lift the molding edge and put a thin bead in there.
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
2) '85 S10, 3.4, 700R4 4x4 stretch cab (Redneck) 3) '90 S10 2.5, 5 speed shorty
6) '83 S10, 327, TH 350, shorty (13.00 best)
7) '92 S10, 2.5 5 speed, Shorty
8) 1979 LUV, Buick 3.8 V6, TH 350 Shorty.
Mad Max is offline
post #14 of 16 Old 10-27-2014, 09:02 AM
User is: thatblindguy is offline
I bought a jimmy with a brand new deal included but not installed. What adhesive/sealer should I use to install it?
post #15 of 16 Old 10-27-2014, 07:51 PM
24digger's Avatar
User is: 24digger is offline
I would let a professional install it if it were me. Shouldn't be too much to have done.
24digger is offline
post #16 of 16 Old 10-27-2014, 08:44 PM
Thanks!
