Whats this plug?
Old 11-04-2009, 02:23 AM   #1
Whats this for?
mr spree's Avatar
Whats this plug?
Its coming out of the original harness that leads to the heater box and what not....
Its a 1992 S10 that originally had the 2.8l
Thanks for any help
Old 11-04-2009, 03:09 AM   #2
Stealin JTC's sandwichs
MadMikeZ28's Avatar
Location: In jtc's basement eating the salami sandwich from his fridge
Re: Whats this plug?
what color are the wires?
Oh and show a better pic of the whole motor. That may help also
Old 11-04-2009, 04:03 AM   #3
96BMW318TiLAYINbdy
dguzzardo22's Avatar
is that a coolant temp sensor plug???
Old 11-04-2009, 01:28 PM   #4
easterwabbit
fastr68's Avatar
hmm wow thats odd. relays on pass side and that plug that ive never seen on a first gen before
does it have 4x4?
hmm
interesting.
the onlth thing remotely close to that with that shape that i can find is r the distributor
Old 11-04-2009, 07:53 PM   #5
Busy at school
jtcfanof3's Avatar
For the coil? Have a connector #?
Old 11-04-2009, 10:25 PM   #6
MadMikeZ28's Avatar
The coil would have two plugs that kinda interlock together.
The plug looks as if it was recently zip tied to the harness. Wire colors may help out lots. I don't recall if its on that side so what side is the washer bottle on? Maybe for the pump.
Old 11-04-2009, 10:32 PM   #7
Busy at school
jtcfanof3's Avatar
Ya, I knew my coil has two plugs, not even the same style plug on my 89. Maybe someone used an aftermarket coil?
Washer bottle is on the driver side. Get me a connector number and I can find out.
Old 11-06-2009, 05:36 PM   #8
Pickup Man
flhthemi's Avatar
I looked under my hood the plug is connected but damn if I can tell where it goes cause both ends run right back into the plastic loom! I did note that it has a black and a green wire and one side of the plug comes from the loom out of the fire wall and then a small piece of loom runs to a big one that runs along the top edge of the valve cover on the passenger side then a small loom comes off that and goes down to a water temp sensor? between the first two spark plugs on the passenger side. The sensor has a green wire attached to the plug on the sensor....so maybe it's for the temp gauge? Does your temperature gauge work?
Old 11-06-2009, 06:09 PM   #9
MadMikeZ28's Avatar
Sure would be a lot easier to confirm if the OP would have put what color the wires are.
Old 11-06-2009, 09:19 PM   #10
looks like the coolant temp sensor to me
Old 11-07-2009, 10:15 AM   #11
v8s10dave's Avatar
I believe that is to the a/c comp wires
Page generated in 0.57822 seconds with 31 queries
[Output: 73.16 Kb. compressed to 68.27 Kb. by saving 4.89 Kb. (6.68%)]
