Whats the biggest tire size for a 2wd s15 ? - S-10 Forum
post #1 of 8 Old 05-04-2011, 09:04 PM Thread Starter
User is: TrapperBB is offline
Hey, im thinking of putting a set of 235/75/15 tires on my dime and nickel. I was just wondering will the fit ok ?
post #2 of 8 Old 05-04-2011, 10:08 PM
User is: my long 10 is offline
Re: Whats the biggest tire size for a 2wd s15 ?
I have seen 4x4 dimes with those and no problems. One of Petersen's off road magazines listed you can put up to 33' but with body lift.
post #3 of 8 Old 05-05-2011, 12:20 AM
jman85's Avatar
User is: jman85 is offline
33's good luck my 85 had a higher stance then most some suspenion package tbars tweaked n 3 inch bl couldn't fit more then 31's without trimming and positive back spacing.
btw 235's came factory on 4x4's body lift should allow you to clear em on a 2wd
1985 gmc s15 4x4 high sierra 5 speed 2.8l reg cab short box 3 inch body lift SOLD
1991 gmc jimmy 2 door 4.3l auto 4x4 lifted 2 inches on air SOLD
highly modded 97 dodge diesel 4wd 5 speed fully loaded making 450hp and 28mpg.
93 sle 4wd 4 door jimmy
jman85 is offline
post #4 of 8 Old 05-05-2011, 09:57 AM
Maybe i remembered that wrong. Gonna have to go back and look.........
Ok. The mag is 4x4 Garage and it claims that amount of lift needed on 4x4 to fit size:
31'tires 2-3' lift
33'tires 4-6' lift
35'tires 5-6' lift
37'tires 8' lift
38'tires 9'+ lift
So this info is only good for 4x4, but i would think you should be able to squeeze 30' in a 2x4. I have 225/75/15 and more room to play with, looks like i could fit 235/75/15 no problem.
post #5 of 8 Old 05-05-2011, 02:34 PM
jman85's Avatar
How about at full lock they will rub on the front go do some look in the 4wd lifting it part of the forum lots of info in there i have seen 2wds with 33 but it had a long arm suspenion kit
jman85 is offline
post #6 of 8 Old 05-05-2011, 03:31 PM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
My 4x4 dime has 235/75 -15s on it, one of my 2x4 dimes has 235/70 15s on the back and 215/60 15s on the front. 235s on the front of a 2x4 might be a stretch...
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
2) '85 S10, 3.4, 700R4 4x4 stretch cab (Redneck) 3) '90 S10 2.5, 5 speed shorty
6) '83 S10, 327, TH 350, shorty (13.00 best)
7) '92 S10, 2.5 5 speed, Shorty
8) 1979 LUV, Buick 3.8 V6, TH 350 Shorty.
Mad Max is offline
post #7 of 8 Old 11-20-2011, 07:55 PM
aletheian's Avatar
User is: aletheian is offline
I know this is a few months old, but I have 235 75 15's on my 100% stock 2x4 s10. They rub when the wheel is turned all the way. I think I am going to try 225 75 15 next time I need tires. The 235's aren't bad except for when I'm up at camp and need to make some sharp turns on the tiny dirt road.
post #8 of 8 Old 11-21-2011, 06:45 PM
peace and big boobs to u
phantom_mia's Avatar
User is: phantom_mia is offline
instead of going 225 stay with the 235 and drop to a 60(235/60/15) i think you'll be pleased . height is the second number
mike
"primer express" 91 RCSB, 4.3 z, 3713 Edelbrock intake and headers, flowmaster exhaust, comp cams 266hr cam and roller tip rockers, ported heads, 3:08 rear. boss 338's 18x8 225/45/18 f 255/55/18 r
ADVANCED FORUM SEARCH
http://www.s10forum.com/forum/search.php
opinions expressed are my humble $.02 worth
