replacing starter soloniod need help please - S-10 Forum
post #1 of 10 Old 05-01-2002, 01:08 AM Thread Starter
mmhyson's Avatar
User is: mmhyson is offline
Send a message via AIM to mmhyson
iam attempting to replace my starter soloniod tomarro i don't know where it is or how difficult it is i got the part and i don't have the money to have somone do it for me so anyone that can giuld me i would appreciate it oh i have an 89 4.3 blazer 4x4 thanks mike
mmhyson is offline
post #2 of 10 Old 05-02-2002, 07:44 PM
User is: rick is offline
Cool easy
O.K. guy,you need to unhook your battery(+),then crawl under the truck(after makin sure you have something under the wheels,so it won't run over you!)on the pass.side . look up at where your trans and motor bolt together and there sits your stater motor.you need to take your starter off by removing the 2 long bolts and most likely there is a small brace that is mounted on the front of the stater to the engine block.when you have your strarter pulled donw a little ,unhook the large batt.cable and the small wire(usually purple)from the solonoid.the solonoid is bolted on to the starter with 2 small screws or bolts.take them out and give it a twist,it should pop right off!put the spring back in,bolt the new soloniod back on,hook up the cables(be carefull not to over tighten the nuts,that hard plastic will break on you)and the studs are easily pulled out.replace starter,not forgetting any shims that may have been between the starter and motor block,PUT THE FRONT BRACE BACK ON !!!even if its a pain to get to.hook up the cables and give her a try.Its really not a bad job and if you take your time you can do it in an hour.Good Luck
rick is offline
post #3 of 10 Old 05-02-2002, 08:29 PM
I rape little boys
User is: badassminitrk is offline
Send a message via AIM to badassminitrk Send a message via Yahoo to badassminitrk
its 4x4...so there will be a frame suppor you will need to remove too
post #4 of 10 Old 02-22-2010, 07:18 PM
User is: jah328 is offline
Re: replacing starter soloniod need help please
where is the frame support that needs to be removed?
jah328 is offline
post #5 of 10 Old 02-22-2010, 11:16 PM
User is: MadMikeZ28 is offline
You responded in a very old thread.... Kudos for searching!
If I acted like some of the people here do and ran to someone when ever my feelings were hurt I would have been called a sissy and then ridiculed for that as well. I suppose I just grew up in a time when we were all tougher and turned out to be men and women instead of staying crying children.
post #6 of 10 Old 11-03-2010, 07:26 PM
Better post-em.
comics22's Avatar
User is: comics22 is offline
i searched too wheres my cookie???
anyways the solenoid on my 92 jimmy 4.3 4x4 4 door is going kaput (or its sticky, only does it when its cold) can you replace just the solenoid on these?
is there a brace that needs to be removed? ive changed the starter on my 95 2.2L and that was a bitch...
comics22 is offline
post #7 of 10 Old 11-03-2010, 09:48 PM
ASE certified MasterTech
jtcfanof3's Avatar
User is: jtcfanof3 is offline
Send a message via AIM to jtcfanof3
Yes, it's just a little cheaper than a complete starter, I would spend the extra money and replace the starter, or if you can buy the rebuild parts then rebuild it.
1989 Chevrolet Blazer 3.4
1989 Chevrolet Blazer 4.3 4x4
1989 Chevrolet Blazer 4.3 Edelbrock equipped
2003 Chevrolet S10 4.3
1999 Chevrolet S10 Xtreme 2.2
post #8 of 10 Old 11-03-2010, 11:24 PM
Better post-em.
comics22's Avatar
hmm ic, the motor seems to be fine and cranks fast when it is working.
comics22 is offline
post #9 of 10 Old 11-04-2010, 04:54 AM
i saw what you did there!
fast68chevy's Avatar
its harder to get the started off the truck than it is to replsace the solenoid
the 2.2 are the worst by far though
the 4.3 arent fun either, but are more fun than the 2.2
the 2.2 starter replacement most of the time is less fun than getting bit by a big mean dog
but some 4.3 are about as fun also,
its pretty random
sometimes theres a brace and sometimes theres not
depends on if its been worked on already, or the application, etc
you wont know anything til you start pulling bolts and wire nuts
its different each time
even same years and engines,
weve replaced a few solenoids recently and a 2.2 starter i did on a 94 pickup recnetly and omg it was about the worst gm one ive ever done omg and the brace was still intact i had to bend the hell ouy of it in order to get the starter out and i did not bend it back! screw that!
i also had to cut the solenoid wire along the engine about 6 or 8" of it because there was no physical way to get to the wire nut for it with the starter under the truck
i just spliced the wire back together after i swapped it to the new starter
what a boitch.
the 2001 2.2l s10 truck we replaced the engine in recently that starter we just had to replace a few days ago and what the hell it was cake walk wtf? same damn truck and engine jut a little newer but totally different
i dont understand it..
its crazy...
you just dont know for sure until you get into it.
nothing is for sure!
post #10 of 10 Old 11-04-2010, 08:10 PM
Better post-em.
comics22's Avatar
ah crud haha. how about the O2 sensor? i feel i should replace that after 166K on it now...
comics22 is offline
