replacing motor mounts - S-10 Forum
post #1 of 13 Old 05-09-2009, 03:08 AM Thread Starter
User is: basist_4 is offline
How hard is it to replace the motor mounts in a 1st gen?
It's a 2wd - 4.3L v6.
Any tips or tricks that may help me get this done?
I did my Saturn last month, but that one is right on top, not underneath the engine...really easy, and there was even a video on Youtube with someone doing it...I'm guessing the ones on my truck are not going to be that simple and straightforward...
If I attempt this, I'll be doing it in my garage w/ nothing but a simple set of hand tools, floor jack and jack stands...step by step instructions would be great, but I'll take any/all information I can get.
I posted this in the 4.3 forum, but threw it here as well since I have a 1st gen...Thanks in advance...
91 GMC Sonoma 4.3 V-6 Auto...bone stock
ext. cab
Want a good body? Work at it. Want to be a success? Work at it. Want to be truly exceptional? Be a touch insane...
You need a little bit of insanity to do great things."
- Henry Rollins
basist_4 is offline
post #2 of 13 Old 05-09-2009, 05:15 AM
User is: MadMikeZ28 is offline
Re: replacing motor mounts
Well at least you have a 4.3 so it should be much easier than say a 2.8 as for those you need to go through the control arm opening.
The mounts for the 4.3 should be on a perch that sits off the frame a bit. If you have an engine hoist you could use it too lift up the motor a bit once the main bolts are removed.
If I acted like some of the people here do and ran to someone when ever my feelings were hurt I would have been called a sissy and then ridiculed for that as well. I suppose I just grew up in a time when we were all tougher and turned out to be men and women instead of staying crying children.
post #3 of 13 Old 05-09-2009, 05:47 AM
User is: just plain bill is offline
Before you raise the engine to get clearance to remove the mounts, take the distributor cap off and move if forward a bit so that you don't break it when you raise the engine. It's already close to the firewall.
post #4 of 13 Old 05-09-2009, 09:00 AM
peace and big boobs to u
phantom_mia's Avatar
User is: phantom_mia is offline
yeap cap and rotor will give you a little more room, also a piece of wood like a 2x4 about a foot long place it on something solid like the trany bell housing with a jack under it to jack the motor up a little after you take the bolts loose on the motor mounts
mike
"primer express" 91 RCSB, 4.3 z, 3713 Edelbrock intake and headers, flowmaster exhaust, comp cams 266hr cam and roller tip rockers, ported heads, 3:08 rear. boss 338's 18x8 225/45/18 f 255/55/18 r
ADVANCED FORUM SEARCH
http://www.s10forum.com/forum/search.php
opinions expressed are my humble $.02 worth
post #5 of 13 Old 05-10-2009, 02:00 PM
User is: bg's is offline
No perch on mine when I did em. MAJOR PITA. I did find
one slot on the left side crossmember that allowed me a
bit of room to get a wrench in there to hold the nuts while
I unbolted the pad mount, but on the right side I had to
open up the cross member to access those nuts. For me
it was a job. I installed ply mounts in it so I wouldn't
have to ever change them again, but wish they didn't
vibrate the engine so much through the frame.
JTR is suppose to make a really nice rubber/poly mount ?
Anyway it's not fun.
bg's is offline
post #6 of 13 Old 05-10-2009, 08:29 PM
User is: AK99 is offline
My driver side mount is broken, made it hard to get third gear during hard acceleration. I bought new mounts and then decided it looked like more work than it was worth to replace them. I just rigged up a limiting cable for the driver side of the motor to keep the mount from separating. Works like a charm and is holding up just fine.
'91 S-10 Longbed
SGT in a rusty S10 wrapper, 4/3 drop, 350tbi/NV3500 coming soon
AK99 is offline
post #7 of 13 Old 05-11-2009, 12:38 AM Thread Starter
Thanks for the replies so far...now, where to purchase the mounts...I'm thinking the poly mounts, or at least heavy duty (not OEM) replacements...everything points to this being a PITA job, so I'm pretty sure I'm only gonna want to do this once.
Links??? (for JTR mounts) or other polyurethane or HD mounts.
ext. cab
- Henry Rollins
basist_4 is offline
post #8 of 13 Old 05-11-2009, 03:17 AM
jagsthatrun.com (jtr). Its an S10 to V8 (and other vehicles) conversion site.
post #9 of 13 Old 05-11-2009, 03:47 AM
So you guys don't have that stand for the 4.3's mount? I never payed any attention to other 4.3 s trucks I worked on to see if they had that or not. That stand offsets the mounts like JTR's engine brakets offset the motor for use with the 2.8 rubber mounts.
post #10 of 13 Old 05-13-2009, 10:04 AM
takes 2 balls in our game
s10-den's Avatar
User is: s10-den is offline
Thats only in the blazer chassis.
Oh, forgot to say, if the mounts are sagging and the oil pan is sitting on the frame, then it will be a bitch to do ,The heat sheilds are in the way,and its almost impossible to get a socket on the bolts because they are covered up by the worn out mount.
s10-den is offline
post #11 of 13 Old 12-10-2016, 07:19 PM
User is: timster is offline
Pulling this old thread out because I don't find a newer thread on 1st gens with 4.3s covering it.
My two wheel drive 91 Jimmy has collapsed mounts. Drove the front up on ramps, lifted the driver's side of the engine, and could access the through bolt and two lower bolts that attach to the cross member. Could not find a way to get a wrench on the upper bolt connecting to the cross member. Not sure if any of that makes sense. If it does, how do I get the upper bolt out?
Also, driver side I have a factory lift point as part of the alternator mount. What can I use to lift the passenger side of the engine up enough to access the 3 bolts to the cross member, the through bolt, and keep it high enough to get a non-collapsed new mount installed? Or do I have to jack the engine or trans up from the bottom? I am not sure if there is room for a jack underneath along with room for me to crawl under and get to the bolts.
Thanks in advance.
timster is offline
post #12 of 13 Old 12-19-2016, 01:44 AM
User is: DaveP is offline
2 wheel drive 4.3's are not too difficult.
4X4 4.3's are almost impossible with the engine installed. The trans hits the top of the tunnel before you can get the clearance to get on the mount-to-block bolts. You have to remove the core support to frame, and the front body to frame bolts and lift the cab off the frame by about 3-4". In a Syclone or Typhoon, because of the exhaust and manifold differences, it's quicker to pull the engine than attempt mount replacement with the engine installed.
I see references to "removing the mount to frame bolts" in this thread. Why? Unless you're changing to 2.8 style JTR mounts, the pads stay in place. The 4-door, Sy and Ty, and ext cab 4.3's all have "flat" bolt on frame pads. The 2-door, 2WD Blazer has a 'tower' pad for driveline angle. AFAIK all 4.3 frame pads are bolted on, and are a bitch to get to the bolts with the lower a-arms still in place. With them removed access is straight forward. The assembly plant installed the pads before the suspension was installed.
DaveP is offline
post #13 of 13 Old 12-20-2016, 01:27 PM
JAD
JAD's Avatar
User is: JAD is offline
Has another posted.. if those mounts have 'sagged' over the bolts, IT IS A PITA to get them out... When I did mine, or should say had them done.... I was still working @ a GM dealer. The tech used a torch to 'cook' the rubber and got them crispy, then chipped off the sagging rubber to get to the bolts. At the time I think I had 160,000 on the OD. They still haven't changed the configuration of these. No steel bracket to hold the rubber in place. What should be a fairly easy job going in, could be a Christmas spoiler, and knuckle busting new year. Hope not...
!991 Sonoma ST 4.3Z 700R4 350,000+ OD
JAD is offline
