remote start on a tbi 4.3 v6?
Old 11-09-2009, 08:36 PM   #1
das89s10's Avatar
can a remote start car alarm be put on a 4.3 tbi v6 just wondering?
Old 11-09-2009, 08:49 PM   #2
Truckless Member
roboticsguy's Avatar
Re: remote start on a tbi 4.3 v6?
Absolutely.
I've installed them on several different S10 pickups and Blazers from the late '80's to the mid '90's. As long as it's fuel injected, regardles of fuel injection type, you're good to go.
Old 11-09-2009, 08:49 PM   #3
absolutly yes......i love mine on the cold azz New England mornings
Old 11-09-2009, 11:00 PM   #4
2Low4Comfort's Avatar
can you do it to a 88 2.5 s10 even if its 5 speed? if possible please let me know
Old 11-09-2009, 11:54 PM   #5
eatinpavement's Avatar
you can but its not safe to. if you forget it in gear and try to start it it will take off and hit whatever is in the way
Old 11-09-2009, 11:56 PM   #6
okay so as long as i leave it out of gear and the E brake on casue i never leave mine in gear unless im on a hill and the only hills around here is the store hill i stop on.. but as long as i leave it in neutral and e brake on its possible they hard to install..
Old 11-10-2009, 12:43 AM   #7
Truckless Member
Yep..I put one in my 1999 S-10 (4 cyl 5 speed) when I had it.
You HAVE to remember to leave it in neutral and set the parking brake. If not, you'll be chasing it down the street, retrieving it from your neighbor's yard, etc...
Old 11-10-2009, 04:09 AM   #8
Matt Smith
350X's Avatar
Cept for whats been said about a stick, yes.
[They won't install one in a stick car/truck, gotta do it yourself. Legal issues ya know.]
Only other hitch would be does it start up fine in the cold?
I think most of them systems will only try 2-3 times.
Old 11-10-2009, 05:01 PM   #9
Long live the Rat Fink
Big Pappa's Avatar
Clifford and Compustar make great systems for manuals, None of the set up crap in the "autostart" brands. As long as the truck is in neutral and the E-brake is on it will start
Old 11-15-2009, 10:07 PM   #10
easterwabbit
fastr68's Avatar
oh hell, something i forgot about that ive been needing to do on mine
damn
good thread!
Old 11-15-2009, 11:53 PM   #11
Truckless Member
This is true for the most part. On most units, the crank time can be changed. If a fuel injected vehicle won't start on a 3 second crank, and/or by the 3rd attempt, something's wrong.
Personally, I like the Valet brand. I've had the least amount of trouble with them.
Old 11-16-2009, 05:13 PM   #12
DiRT 2 fannatic
adamwilkes20's Avatar
what do you have to do with manual S10, cause wouldnt the switch on the clutch foul it up, or do you have to bypass it? I cant crank mine in neutral without the clutch pressed.
Old 11-16-2009, 10:26 PM   #13
Matt Smith
350X's Avatar
On the clutch switch, Id hook up a toggle switch to it, to have it bypassed for remote start and normal start. That way you can disable that function for someone who doesn’t drive it often. They forget, leave in 1st and off it goes.
