posi rear end question - S-10 Forum
post #1 of 11 Old 03-19-2008, 02:31 AM Thread Starter
User is: sittinglow10 is offline
i seen a video of a s10 with a 2.8 and it had posi trac and i was woundering how to get my 82 s10 2.8 rear end to have posi
post #2 of 11 Old 03-19-2008, 03:02 AM
chsdrummer07's Avatar
User is: chsdrummer07 is offline
Re: posi rear end question
You can either redo it yourself and MAYBE get it right or just go buy a posi... personally id go buy one. it'll be cheaper in the long run with how many people screw up their rear ends trying to do it themselves.
post #3 of 11 Old 03-19-2008, 10:39 AM
User is: sfhellwig is offline
It's been a while since I looked into it but one route is a Zexel Torson(sp?) unit which was around $100 last time I checked. Only issue is it requires 88' or later axels so you would have to swap those which might require new gears. I don't know rear ends that well so I didn't look any further. I just figured if I ever did it I would get a newer year assembly and look for lower gears at the same time. Figured it would be cheaper to junk yard an entire axel than replace every thing in the one I have.
post #4 of 11 Old 03-19-2008, 02:50 PM
exactley... there's so many people that end up having to buy both replacement parts and new axels because they try to replace it and dont know what they're doing. And actually I'm probably gonna be buying a posi pretty soon so if any one cares I'll let you know how it goes haha
post #5 of 11 Old 03-20-2008, 11:16 AM
s10kool's Avatar
User is: s10kool is offline
when i did my first sbc s10 i got a stock p-trac out of a 96 camaro and axles out of a 92 s10 and worked great in my 84
s10kool is offline
post #6 of 11 Old 04-03-2008, 12:24 AM
16grem72's Avatar
User is: 16grem72 is offline
i went to the junkyard. in the glove box look for a g80 code. this is a posi unit. I pulled it out found a gt5 code truck and got 4.10's put them together and had 4.10 posi. If you dont know how to pull the gears then you probably should hire someone else to put them in. most times the junkyard will just cut the entire center section out and sell that to you if you ask. but i've always just pulled my own.
16grem72 is offline
post #7 of 11 Old 04-05-2008, 02:40 AM
Registered Minitrucker
hac327's Avatar
User is: hac327 is offline
Send a message via MSN to hac327
not to try and jack this thread but i have heard a little about this g80 code,...where exactilly? on a sticker or in the vin string or what?
01'S10,2.2l 5sp,All Black,2-3"lower,18"ADR Offset rims,3500w,2 AudioBahn 12"X K&N FiPk,tinted out,flows,custom dash paint,and some custom flames here & there
http://www.s10forum.com/forum/f30/pr...3/#post6118646
hac327 is offline
post #8 of 11 Old 04-05-2008, 02:50 AM
Truckin' on a budget
riddic1985's Avatar
User is: riddic1985 is offline
Send a message via Yahoo to riddic1985
Its on the sticker in the glove box with all the other codes. Dont know the exact position just look through the codes for G80
post #9 of 11 Old 04-06-2008, 03:13 PM
16grem72's Avatar
in the glove box are RPO codes. the location of individual codes changes from vehicle to vehicle depending on the options. there normally are between 4 and 6 rows and about 10 columns. I have found the code all over so you just have to look around a little. more codes the more options.
if your looking for gears
Gu2 - 2.73
GU4-3.08
GU5 - 3.23
GU6 -3.42
GT4 - 3.73
GT5 - 4.10 Just check on the pinion gear to make sure someone didnt change it.
16grem72 is offline
post #10 of 11 Old 04-08-2008, 12:44 PM
User is: KaP10 is offline
Send a message via MSN to KaP10
or you could just weld up the spider gears. (if your really cheep)
KaP10 is offline
post #11 of 11 Old 04-09-2008, 11:10 PM
i pitty the fool!
swamp_rat's Avatar
User is: swamp_rat is offline
Send a message via AIM to swamp_rat Send a message via Yahoo to swamp_rat
only the s10 sized 7.5 gears would fit or would the fullsize 10bolt gears from a 8.5 would fit?
