Parts compatibility
Old 07-18-2008, 11:17 AM   #1
Gadget_guy_1984 is on a distinguished road
Parts compatibility
I have an 87 S10 pickup extended cab. in less than four years I have put over a hundred thousand on it using it as a landscaping truck, so may of my parts are practially shot. a local shop had a 91 s10 pickup extended cab with many of the parts i need. I just need doors fenders and some interier parts. But the parts guy at the local gm dealer doesn't think that they will fit. that truck has a shot engine and trans and had a minor fire that fried the harness. I guess the question is does anyone know if these parts are compatible? my truck runs and drives great i just kinda suck at body care.
Eric
Old 07-18-2008, 11:20 AM   #2
jakethegriff's Avatar
jakethegriff will become famous soon enough
Re: Parts compatibility
meh, the exterior should not be a problem, with the exceptions of the grill & lights, but that can be made to work, as far as the interior, i guess it depends on which parts, the dashes & consoles are different. the door panels are as well, but i don't see why they wouldn'nt work on yours. As long as you have the same options, PL,PW and what not...
Old 07-18-2008, 11:24 AM   #3
the seats are the other thing I was thinking about taking. mine don't recline but those do and everything is the same no power options except mine is a auto trans
Old 07-18-2008, 11:26 AM   #4
the seats will work no problem, the only thing that wont is the dash parts, unless you do a FULL dash swap.
Old 07-18-2008, 11:28 AM   #5
dropped_dime88's Avatar
dropped_dime88 is on a distinguished road
really the dash is different my friend swapped some stuff off a 92 into a 88
Old 07-18-2008, 11:31 AM   #6
I did consider a full dash swap because the interier on the donor truck is a gark gray or black and mine is red. but if I do just the seats I can just get a set od mossy oak seat covers.
Old 07-18-2008, 11:33 AM   #7
good information to know
Old 07-18-2008, 11:39 AM   #8
Truck #121616
Golana's Avatar
Golana is on a distinguished road
i think 88 is when they updated the interior to the newer style 1st gen.
im doing a full dash swap from a 89 into my 83. so many more options for the newer style dashes.
but yea, anything on that truck should swap onto your truck bro.
if you need the grille, get the core support too (so the grill fits properly)
if you need the doors, they will fit no problem.
fenders will fit
as long as the box style is the same; shortbox to shortbox, it will swap
anything will swap over, just depends on how involved you wanna get.
Old 07-18-2008, 11:57 AM   #9
fenders will fit
yeah thats what i was thinking and im doin a full core swap for my 88 to a 93 front end, new core support,grill, projector headlights, bumber,valance, and even the radiator
Old 07-18-2008, 12:05 PM   #10
Truck #121616
Golana's Avatar
thats what ill be doing with my 83. everything about it is going to say newer 1st gen hahaa! ive already got 99% of the newer dash in my room assembled. just waiting on the main wire harness and a head unit holder, and then the dash will be ready to go in.
Old 07-18-2008, 12:08 PM   #11
how hard was it gettin the dash out cause im thinking about swappin mine?
Old 07-18-2008, 12:16 PM   #12
Truck #121616
Golana's Avatar
its not overly that hard.
you have 4x 9/32" screws on top by the vents
then you have 4x 10mm bolts on the bottom. the dash will come loose, pull it a bit to get behind it, and see what's holding on still.
the only sizes for anything on the dash will be wither 9/32" or 10mm, with the exception on the HVAC controls, which uses like... a 6.5mm screw... i just use pliars on the little one-way washer thing that holds the cable onto the temp control. then i break off the one-way washer things from the hoses on the zone control.
oh, if you take the newer style dash, you will also have to grab the peg that bolts to the firewall to support the bottom of the dash in the middle. i think you may also need all the venting... not too sure though...
Old 07-18-2008, 12:16 PM   #13
oddly enough the bed is in good shape, the only thing is that my window tracks are bad and when open them without holding the back of the window they go off track. one of my fenders was hit in a parking lot, I just want to get it back the way it should be. I am just going to order the carpet kit from LMC Truck since it is only $159. I also have brand new grille and headlight bezels so I am not worried about the grille, but when he told me I could have the whole truck for $200 the doors alone are worth more.
Old 07-18-2008, 12:18 PM   #14
Truck #121616
Golana's Avatar
i would not hesitate to pick the truck up for $200 man
Old 07-18-2008, 12:19 PM   #15
my next project for this is I have a 327 and a turbo 400 to put in this but I won't be touching that for a couple of months because untill boating season is over I am not going to disable my truck.
Old 07-18-2008, 12:21 PM   #16
hell no dude since it had no title I am going to just tow it up to the junk yard for the scrap value once I get everything I want out of it
Old 07-18-2008, 12:21 PM   #17
Truck #121616
Golana's Avatar
nice, thats awesome. wish i had a 327 :P
Old 07-18-2008, 12:22 PM   #18
Truck #121616
Golana's Avatar
what do you mean hell no?
i would do just what you said. get what i want out of it, then scrap it
Old 07-18-2008, 12:23 PM   #19
the nice thing about being a manager of an advance auto parts, I picked it up from a dumbass who thought it spun a bearing for $50 it was just a damn water pump
Old 07-18-2008, 12:24 PM   #20
my bad I ment hell no I wouldn't pass it up
Old 07-18-2008, 12:36 PM   #21
ol' Grey Hair
lbcblazer88's Avatar
lbcblazer88 is on a distinguished road
Yes pretty much every part will fit exterior wise. And Golana i belive the newer style 1st gens(new grill and such) was in 90 or 91.
Old 07-18-2008, 12:38 PM   #22
Truck #121616
Golana's Avatar
when did they update the interior though?
i think 91+ was when they got the newer grille, but im not sure about interior, cause i pulled my newer style dash from a 89
Old 07-18-2008, 01:05 PM   #23
ol' Grey Hair
im not really sure....my 88 has the different gauges than the older models(like ure dime, btw checked out ure Project thread,good work!) tht have the round gauges.
Old 07-18-2008, 01:07 PM   #24
Truck #121616
Golana's Avatar
thanks bro which project thread did you check out? Blue Bitch is kinda on the backburner right now. im heavily into 83.
Old 07-18-2008, 01:08 PM   #25
ol' Grey Hair
i was looking at blue bitch like yesterday i believe..ima check ure other one out now tho!
Old 07-18-2008, 02:02 PM   #26
alright thanks im goin to be switchin out my dash within this week,
Old 07-18-2008, 02:19 PM   #27
Truck #121616
Golana's Avatar
sweet shouldnt be too hard as long as you have all the right tools
Old 07-18-2008, 02:36 PM   #28
yeah i hope it gooes as planned lol and its probly even easier since i dont have a/c
Old 07-18-2008, 03:04 PM   #29
j0ebro's Avatar
j0ebro is on a distinguished road
ya im pretty sure 86 was the first year of the new interior with the candy cane gauges and such, and 85 back had the flat dash with the round gauges
Old 07-18-2008, 03:09 PM   #30
yeah and i was lookin at your project blue bitch , it looks good
Old 07-18-2008, 09:31 PM   #31
my 87 has about the most basic gauges you can get.
Old 07-19-2008, 12:39 AM   #32
American Muslce
85S10Project's Avatar
85S10Project is on a distinguished road
Yep 86 is when the interior was updated from the round gauges.
82-85 round gauges
86-93 half round gauges
Old 07-19-2008, 01:46 AM   #33
aka WickedTaz
BadasTazMan's Avatar
BadasTazMan
are the seat belts any good??
Old 07-19-2008, 08:01 AM   #34
I won't know untill next friday when I pickup the truck
