MM5 Manual Transmission
It's about time for me to get my Xtreme parked for the winter. I've been working on getting my newest S-10 acquisition ready for the road. It's a 1989 2WD regular cab with a 5 speed manual trans. Right now, the transmission has got Dexron ATF in it, but I'm wondering if this is correct. The owners manual that I got with the truck does not have a listing for the MM5 transmission that is in it. Can anybody tell me if Dexron is the right fluid for it ... or should it use gear lube?
no longer has a 95
Re: MM5 Manual Transmission
mm5? what is that?
the only manual transmissions in 91 are the T5 and the NV3500 2.5/2.8 have the T5 in them and it does take atf the 4.3 has the NV3500 and it takes sycromesch |
NOT DONE TO MANY PROBLEMS
some of the t-5 trannys use the sycromesch oil. That is what i am going to use in mine when i replace the clutch. by the way that shit is expensive, over 10 bucks a quart.
whore turned lurker
keep the ATF
whore turned lurker
the MM5 RPO is for manual 5-spd equipment, like pedals,master cyl., slave cyl. etc.
would it hurt to run dextron atf with the nv3500?
I have the same RPO code and it also says MY2 when I called the dealership the guy could not tell me which transmission by the codes. He said to climb under the truck and look for a tag?
4x4muddevil
wat transmission would my 1983 4x4, 4 or 5spd be? its a 2.8v6
Boozebag
I'm really tired of recommending this:
Honda makes a tranny juice for their manual trannys that is magic. It is a little thicker than ATF and is almost clear. I have 3 dimes with 5 speeds (T5s) and have installed this stuff in each one. It reduced grinding and my '91 goes to the drags pretty regularly. I can beat the synchros most of the time when I power shift, but it is alot less pronounced now. Anyway, it's about $8/qt IIRC and it really works. I also would recommend adding a 1/2 QT of Lucas oil additive. This stuff also works well. It sticks to moving parts. |
Is this a NV3500? and if it is not, what kind is it? I got it with a 2.5 liter from another S-10. Any factual identification will be a plus, as this is the tranny I'm planning on stuffing in my dime.
C'mon folks. I would really like an answer to this, short of loading it up and hauling it to a transmission shop to get it ID'd.
This is the one I plan on stuffing into my dime, and will need a positive ID to get the adapter to switch to a electric speedo. Please help me out. All of the photos I found on the web do NOT have clear enough photos to match this with. PLEASE HELP ID THIS TRANNY!!!!!!!
Super Saiyan User
its def not an nv3500, slave is on the wrong side, almost want to say its not a t5 cause the bell housing isnt removable, and its not an nv1500 cause the starters on the wrong side... so i dunno
2nd pic is an isuzu logo... wouldn't be surprised if that went with the isuzu diesel powered s10 they sold in the mid 80's (1.9, 2.0, 2.2l)
While pretty much indestructible the gear ratio selection in them things were...... not optimal . And as I recall , it ran ATF. |
look up the id# online |
| Sponsored Links | |
Advertisement | |
