Manual window issue '88 S10 Blazer - S-10 Forum
post #1 of 6 Old 03-04-2012, 11:56 AM Thread Starter
User is: bang4dabuck is offline
Rolls up tilting forward. I think regulator is working properly and the window is on both tracks. Not sure if a part is missing or broke. It is like there is too much play in the front track or it got pushed out some. I have to pull the window towards the rear when I'm rolling UP, no problem when I roll down. Well there always was a little hitch while rolling down at about 75% down but I just fight thru it. Any ideas ? Any schematics ?
thanks
post #2 of 6 Old 03-04-2012, 02:24 PM
24digger's Avatar
User is: 24digger is offline
Re: Manual window issue '88 S10 Blazer
There's a black plactic slider clip that goes a hole in the glass near the top. It snaps into the track. You can get them in the help section in auto parts stores.
24digger is offline
post #3 of 6 Old 03-04-2012, 04:19 PM Thread Starter
Thanks. Saw that little hole in the corner yesterday after it pulled that crap. Knew it had to be there for a reason.
post #4 of 6 Old 03-04-2012, 09:27 PM
oldS10srule
User is: fellchase is offline
I struggled with this SAME ISSUE for at least a year.
A little different history perhaps. I put in new channel weather strips.
I got the w/s from LMC Truck they were excellent repro parts.
Rubber felt channel with integral metal backer for mounting to the door channel.
Pretty challenging to install cause its all one piece. Goes way down in the door on front and back hard to get your fingers in there. Anyway after install the glass tip forward when going up. I shotgun it with a known good regulator. No help. New plastic clips. No help. Finally I realized that the channel not seated against frame. Took big screwdriver and hammered against channel and that did the trick. Some sheet metal screws hold channel to frame. Smooth operator now. Long live first gens. Good luck.
post #5 of 6 Old 03-05-2012, 02:54 AM
2003Xtreme's Avatar
User is: 2003Xtreme is offline
I shattered a glass window out once trying to put them clips on.. lol be careful
99 Hugger Orange Z28
93 Suburban Lowered
91 S10 shortbed Lowered
Project Build Thread Links
http://www.s10forum.com/forum/f135/s...y-pics-483887/
http://www.s10forum.com/forum/f135/f...yard-d-483861/
http://www.s10forum.com/forum/f3/198...t-work-489962/
Originally Posted by J_SIN View Post
I'd rather pump up my bags with a bicycle pump than use their products.
post #6 of 6 Old 03-06-2012, 08:52 PM
24digger's Avatar
Some advice I read on here somewhere was to warm them up some and they will go together easier.
24digger is offline
