manual transmission fluid change? - S-10 Forum
post #1 of 21 Old 04-15-2009, 10:03 AM Thread Starter
one bad bow tie
nismo_2005's Avatar
User is: nismo_2005 is offline
hey i want to change the oil in my tranny but i don't know what weight it call for. I call my local autozone but they did not know. could someone plz let me know what wheight to use? thank you in advanced.
by the way 2.5 5spd.
post #2 of 21 Old 04-15-2009, 10:28 AM
GRM Challenge Truck
User is: dusterbd13 is offline
Re: manual transmission fluid change?
use ATF. its a T-5. thats what they call for.
michael
3.4 MPFI DIS swap, 5 speed swap, autometer gauges, tall ball joints, 3/5, and nowhere near stock anywhere else either.
its a spec miata with a bed.
My project thread http://www.s10forum.com/forum/f30/pr...beater-352595/
post #3 of 21 Old 04-15-2009, 10:44 AM Thread Starter
one bad bow tie
nismo_2005's Avatar
ok thank you I just was not sure. from the looks of when i checked it it had some very nice motor oil in there yay. the rear end also that's the main reson I'm changing them both and inspecting the rear end for where.
autozone said 90 for the rear end is that also right?
post #4 of 21 Old 04-15-2009, 10:47 AM
david gmc's Avatar
User is: david gmc is offline
yep,,thats what we used when i worked in a trans shop
post #5 of 21 Old 04-15-2009, 10:54 AM
Have A Nice Day
944v8indfw's Avatar
User is: 944v8indfw is offline
in the rear if you have no leaks it might be a good time to upgrade to a
Synthetic (Royal Purple) type grease. 75-90 is what i use on my trucks. 2 Quarts. Not so sure on the manual trans.
post #6 of 21 Old 04-15-2009, 11:11 AM
User is: workin_ike is offline
while on the topic, whats the weight recomended for the diff. I was going to pull my cover to change fluid casue its leaking anyway.
Confucius say, Common Sense not so Common
post #7 of 21 Old 04-15-2009, 11:14 AM
Have A Nice Day
944v8indfw's Avatar
Originally Posted by 944v8indfw View Post
Synthetic (Royal Purple) type grease. 75-90 is what i use on my trucks. 2 Quarts. .
around $15 a quart
post #8 of 21 Old 04-15-2009, 11:15 AM Thread Starter
one bad bow tie
nismo_2005's Avatar
i just got back from autozone and got me 3 quarts of atf and 2 quarts of 80-90 gear oil.
oh and i had to take back the 5664 springs i ordered cause you will never guess it but they got the wrong ones.
post #9 of 21 Old 04-16-2009, 07:56 AM
User is: Mikey Chalupa is offline
How do you change the transmission fluid for a 5 spd? ( 2.8 TBI by the way)
post #10 of 21 Old 04-16-2009, 03:34 PM
User is: MadMikeZ28 is offline
Autozone did not know what fluid too use..... Autozone markets Alldata. For them to not know what fluid it needs is either a lie because they can look up all the info or Alldata is truly as worthless as I know it to be (I call it Nodata).
To change the fluid there will be two large plugs. One lower than the other. Pull the lower and drain the fluid then reinstall. Then fill from the upper, slowly so the fluid will settle, then when it pours out of the hole it is full. When its a heavy fluid (ATF is pretty light) you would want to allow the fluid to settle for a few minutes and recheck the level and top off if needed.
If I acted like some of the people here do and ran to someone when ever my feelings were hurt I would have been called a sissy and then ridiculed for that as well. I suppose I just grew up in a time when we were all tougher and turned out to be men and women instead of staying crying children.
post #11 of 21 Old 04-16-2009, 03:43 PM
Dump em' Out
Bootylicious's Avatar
User is: Bootylicious is offline
15 bucks a quart...wow!
post #12 of 21 Old 04-16-2009, 03:49 PM
Have A Nice Day
944v8indfw's Avatar
for Royal Purple Gear Oil Considering you change it say ever 50k pretty cheap insurance
post #13 of 21 Old 04-16-2009, 05:11 PM
It also already has friction modifiers for LSD's so you don't need to add any.
post #14 of 21 Old 04-16-2009, 05:48 PM Thread Starter
one bad bow tie
nismo_2005's Avatar
i would say there is a good chance that the employee was just lazy and did not want to look it up. but either way it is done now so I'm happy.
post #15 of 21 Old 04-16-2009, 06:42 PM
adamwilkes20's Avatar
User is: adamwilkes20 is offline
The oil company I work for has developed a pretty good Synthetic G.O. 75W90..We aslo make a good LSD additive to add to MP Gear oils
post #16 of 21 Old 04-16-2009, 10:50 PM
GRM Challenge Truck
before pulling the bpttom plug, always pull the top (fill plug). youre ****ed if you drain all the fluid and cant get the fill plug out.
ask me how i know.
Michael
post #17 of 21 Old 04-16-2009, 11:18 PM
Ehhh!
towb3's Avatar
User is: towb3 is offline
I would hope that was common knowledge. But guess you never know. MadMike is 100% correct on the drain and fill. It is extremely easy, especially if you have easy access to the trans
towb3 is offline
post #18 of 21 Old 04-18-2009, 12:40 AM
david gmc's Avatar
x2 its easy
opinions are like assholes,,
post #19 of 21 Old 04-20-2009, 10:18 AM
Lil'Blue87's Avatar
User is: Lil'Blue87 is offline
how much does the 4 speed hold? (2.5L, 1987)
post #20 of 21 Old 01-18-2011, 05:16 AM
chinoxtreme's Avatar
User is: chinoxtreme is offline
I have an 01 xtreme 4.3 with a 5speed and I have been wanting to change my trans. Fluid. Two questions. First, when I the tranny is cold, like hasn't been run for a couple hours or more, it shifts, engages, and disengages smoot and quietly. When it warms up I hear it engage and disengage sometimes with like a metal to metal clap. If I throw in a good high quality fluid you guys think it'll help a lot or should I be expecting bigger issues? And second. Am I supposed to be using an ATF fluid for my manual transmission?
post #21 of 21 Old 01-18-2011, 02:45 PM
jenike's Avatar
User is: jenike is offline
Go to the dealership and get the synchromesh fluid for the manual trans. I've had the best luck with that and it's fairly cheap.
jenike is offline
