GettingPainted
I've Got A Pretty Nasty Problem
I posted this in the wheels section but got no response. Im not really sure what category this would fall into.
but anywho, here's a chunk of the inside of my rim. ![]() ![]() Im not yet driving my truck, but i was pulling it out of the garage and had to make a sharp turn, i felt it scrub and looked at the ground and found that, and then some. But my A-frame that is rubbing the inside of my rim and tire. my truck is a 90' reg cab slammed 5in. in the front and 6 in the back. im running quarter inch spacers on my rims, and im pretty sure they are 15x8's. i know my front end isn't aligned, so im going to take it to a shop to see if that fixes anything, but if not, do you guys have any ideas how to fix this? and sorry for the double post. |
<3 redheads
Re: I've Got A Pretty Nasty Problem
are you sure that's from your rim and not the wheel weight? the pic is kinda bright.
GettingPainted
Yeah, its the rim.
there's a scratch half way around the whole thing. |
It Burns When I Pee
Just looks like a wheel weight to me. Bring it to a shop and have it balanced again. Oh yeah, figure out why your rubbing too.
GettingPainted
Im pretty sure its the rim.
GettingPainted
well i take that back, but any idea how to fix this?
trouble maker
go get some 1 inch spacers or 1/2 inch, the problem is your wheel it has the wrong offset for your application
Busy at school
Location: barack hussein obama mmm mmm mmm User is: OffLine |
The chunk in your hand is the wheel weight, even though you've rubbed the rim, that chunk in your hand is the weight. Agreed, your offset is wrong.
GettingPainted
So just get some bigger spacers and i should to be good to go?
thanks guys ![]() |
You...Tonight
what the hell kinda wheels u got on there? and tell them to use stick on wheel weights cuz the clip ons blow
GettingPainted
![]() Colorado customs. |
trouble maker
"bigger spacers" wtf?! dude your running a front wheel drive wheel on a rear wheel drive truck!
You...Tonight
yeah whats the back spacing on them bad boys?
Location: Indianapolis (Castleton), In User is: OffLine |
grind a little off the control arms if need be
GettingPainted
they were on the truck when i bought it.
Banned
Yeah that happened to me a while ago because the wheels were 2 big. and i didn't have adapters! may be ur wheels are also bigger and when u go left or right the wheel touch the frame! so u need to install adapters or spacers.
hope it helps! |
the crap on your rim is from the weight being dragged around from getting caught on the control arm. that should scape off the wheel. you are gonna have to use stick weights like mostizzle suggested. maybe if you have a speed shop or rim shop around they could switch you out for rwd wheelz. but then those wheelz are cool looking. paint the centers to match the truck to custoize them even more
Pickup Man
That tire was made the 30th week in 2002....
GettingPainted
Thanks for pointing that out
half10
yeah grind a little off the arms and have them balance with stick on weights so nothing hangs on the back....had to do that to an s10 once....
