Ignition Control Module 1990 S10 4.3
Hey all, I have a 1990 S10 Baja with 4.3 The truck sat for about a year and not runs like pure crap'o'la.
It's real hard to start, have to hold gas all the way to the floor and crank it over for quite a while, finally starts, stammers, spits black smoke.. finally revs up and sounds normal, idles super low and chunky then dies. You can drive it for about 5-10 mintues but once it gets hot it will puke and die and WILL NOT start again for atleast two hours (almost like it got really rich and flooded) It's Tbi and here's a list of all the things I have done to fix the problem. New Plugs New Wires New Cap New Rotar New fuel pump New fuel filter New ignition relays Checked all fuses Changed oil (lots of gas in the oil!?!) New PCV valve Removed, inspected, cleaned EGR valve Replaced cracked vacum lines Replaced TBI injectors (no change here at all) I got a parts truck it's a blazer with a smaller V6 (not the 4.3) I was gonna try to use the ignition control module from that or even the entire distributor if that's even possible. Any thoughts??? Thanks much! |
peace and big boobs to u
Re: Ignition Control Module 1990 S10 4.3
ok for starters since you got a baja they are going to want to see pictures.
when you changed the fuel pump did you clean the tank out and dump the old fuel? with lots of gas in the oil i would be suspicious of the intake manifold gaskets being fubared, do you know why it was parked for over a year? |
Yes when I did the fuel pump I removed all the old fuel and inspected the tank which was PERFECT inside.
I've had the truck since 04' it has been very very good to me, I parked it because I got an SUV for free that became my daily driver... then I bought a car and so on.. The truck just sat unused but recently I've been dirt biking a lot and using a snowmobile trailer behind my SUV is getting... well.. rediculous to haul dirt bikes when I have this truck :-) |
hey i understand, i was driving 100 miles a day round trip back in 00 to 03 and i bought a hyundai and my truck basically sat in the garage till 05 and when i went to start it it didn't. but with mine the fuel had evaporated and gumed up the pump.
have you had any thoughts about the intake manifold gaskets? |
ASE certified MasterTech
Location: A little here and a little there.... User is: OffLine |
Have you looked at the IAC valve, what about the fuel filter being turned in the correct position, flow arrow as designed?
Have you checked the fuel pressure, yes I have gotten bad pumps before. |
Not real familiar with the engine but maybe a crank position sensor just a thought
P
No CKP sensor on these engines.
That's what I figured just a guess have you checked the timing on the beast? Also have you checked for spark at all the cylinders. Another good idea would be to check the compression on it. Perhaps bad gaping in the distributor? Maybe a wire was crossed from the previous owner. Just shooting ideas out some input is better than none i guess lol
But personally I would start with checking the compression with the gas i the oil thing sounds like a blown piston ring. Kinda hard to diagnose with out hearing it.
| Sponsored Links | |
Advertisement | |
