Truck #121616
How-To: Cruise Control Light (digital cluster)
Well, i figured i should write a tutorial on how to do some of the stuff i do, so i can help you guys out
![]() I wanted a Cruise Control Indicator, and GM put one into the cluster, but didnt follow through with making it work... slackers! Well, I wanted one, and I was determined to make it work for my truck. Now that I have, Im sharing my knowledge and findings with you all. First off, its a very simple procedure to do, so start by removing the metal back plate from the cluster. Socket size is 7/32". With the backing removed, find the bottom left light socket hole (the one just above the torx screw), and using an Xacto knife, gently cut where i have. What you want to do is cut the copper track at the top to separate it from the other circuits, then cut about 1mm down from your other cut, and peel the copper up so it is its own circuit. ![]() Now with that cut out, find the 'Check Fluids' indicator that GM didnt finish either (its right beside the Cruise light), and cut the tracks just past the solder point, like I have. Now you are almost all done. I scratched up the coating on the copper track (what was left of it) from the Cruise light, and soldered a bridge wire to the Check Fluids light track. ![]() Now you want to solder a little bridge wire from the Cruise Control light side to the Ground pin (pin#24) like I have. Then you can either get a spare plug, and steal wires from it, or do what I did and just used the Seat Belt indicator wire. Using a bobby pin (or whatever you have), feed it into the pin side of the plug (nearest the outside) and wiggle until the wire comes loose. Now simply just plug the wire into slot #29. ![]() Now that you are done the hardest part, all there is left to do is hook up wire #29 to the GREY wire on the Cruise Control Module. ![]() With that done, all it takes to turn your light on is to turn the Cruise Control on! And that's it for this mod! ![]() Sweet! |
Location: Indianapolis (Castleton), In User is: OffLine |
Re: How-To: Cruise Control Light (digital cluster)
Very good. Turned into a sticky.
"better days"
thats nuts
Chivalay Mane
nice......ill be doing this soon
Truck #121616
nice
take pics and post your results here ![]() |
94 s10 in progress
does the BASIC thing apply the the 94 truck cluster?
Truck #121616
whore turned lurker
is that with the digital cluster or which one is it?
Truck #121616
94 s10 in progress
the 94 cluster has a whole boat load of un used features
a/c oil change air bags (may use this one for when i bag it) i believe cruise drl theres a few more i will have to look on my old cluster and find out this is also the analog with tach 94 only Last edited by FxsX24 : 08-27-2008 at 12:01 AM. |
whore turned lurker
Truck #121616
Have you seen my glovebox
how about this.. low fuel light on a 97? anyone have any experience trying to get it to work
btw, i know this is a 1st gen forum but im just wondering.. |
Truck #121616
square body love ftw! |
Truck #121616
im really sorry, everyone, for the images being down... im trying to find them again... my website went down, and i had the images all linked to it. same happened to my project threads...
i am looking through 10,000 pictures trying to find the 5 or so that were taken for this how-to haha |
Truck #121616
well, 2 hours later, and i have located and uploaded the pictures
![]() so hopefully a mod can edit the original post and include the new images ![]() just delete this post when the original post is edited ![]() -=TUTORIAL=- Well, i figured i should write a tutorial on how to do some of the stuff i do, so i can help you guys out ![]() I wanted a Cruise Control Indicator, and GM put one into the cluster, but didnt follow through with making it work... slackers! Well, I wanted one, and I was determined to make it work for my truck. Now that I have, Im sharing my knowledge and findings with you all. First off, its a very simple procedure to do, so start by removing the metal back plate from the cluster. Socket size is 7/32". With the backing removed, find the bottom left light socket hole (the one just above the torx screw), and using an Xacto knife, gently cut where i have. What you want to do is cut the copper track at the top to separate it from the other circuits, then cut about 1mm down from your other cut, and peel the copper up so it is its own circuit. ![]() ![]() Now with that cut out, find the 'Check Fluids' indicator that GM didnt finish either (its right beside the Cruise light), and cut the tracks just past the solder point, like I have. Now you are almost all done. I scratched up the coating on the copper track (what was left of it) from the Cruise light, and soldered a bridge wire to the Check Fluids light track. ![]() ![]() Now you want to solder a little bridge wire from the Cruise Control light side to the Ground pin (pin#24) like I have. Then you can either get a spare plug, and steal wires from it, or do what I did and just used the Seat Belt indicator wire. Using a bobby pin (or whatever you have), feed it into the pin side of the plug (nearest the outside) and wiggle until the wire comes loose. Now simply just plug the wire into slot #29. ![]() ![]() Now that you are done the hardest part, all there is left to do is hook up wire #29 to the GREY wire on the Cruise Control Module. ![]() With that done, all it takes to turn your light on is to turn the Cruise Control on! And that's it for this mod! ![]() ![]() Sweet! -=/TUTORIAL=- |
Hey, thanks much, that's neat. Going to try it on my Cameo! I guess i better add the cruise control first.
