The Masked Magician
Heater Core?
This morning driving to work I noticed liquid dripping on the floor from the passenger side dash. It was anti freeze and I could see smoke coming out a little bit. Is this the heater core that went bad? If so is it necessary to pull the entire dash out to get to this thing on a 1st gen s-10. I have only done one other heater core (in a camaro) and I didn't have to pull the dash out but it wasn't fun. I did search and found threads on 95+ heater core installs but can't find any for first gen.
simple man
Location: Belmont, just west of Charlotte, NC User is: OffLine ![]() |
Re: Heater Core?
definitely sounds like your heater core sprang a leak. it's been about 8 or 9 years since i changed one, but i know the whole dash didn't have to come out. if i remember correctly, you get to some of the screws through the glovebox opening after you take the glove box apart.
I SHIT BRICKS
Re: Heater Core?
dude its a pain in the ass lol
paint color? ... Mud =D
Re: Heater Core?
definitely the heater core
i did one in an 88' firebird once it would be easier to take the dash out if you have the time i just used lots of u-joints and wobbles to get to the hidden screws pretty sure its not much different in the s10 |
Re: Heater Core?
Hey man its a PITA!! I had to change my heater core because it did the same thing that urs it doing, had a small drip drip. I didnt take out the dash and it was a BIG JOB! If u have the time i highly recommend that u take out the dash. I took out my dash to find a electrical problem and saw that i could have easliy take out my heater core with the dash out. Anyways good luck and be patience.
The Masked Magician
Re: Heater Core?
Yea I will probably just pull the dash. Thanks for the info.
SoCal Football
Re: Heater Core?
No, no, no..It's not that hard at all. Here is a
how to.Follow it and you'll be fine. I found jacking up the ride on the right side at the door/ fender area helps to get to the one screw on the far right side for the ducting. Other than that, it should only take you an hr or so to pull it WITHOUT removing the dash. You have to take a few components off, but they are very easy to get to. Here. Click pics to enlarge. Thanks to Sy/Ty Archives for the great how to. > http://www.sytyarchives.com/howto/vi...imate_controls |
The Masked Magician
Re: Heater Core?
The Masked Magician
Re: Heater Core?
The Masked Magician
Re: Heater Core?
Wow thanks, doesn't look too bad. Nice write up! |
simple man
Re: Heater Core?
g/l with the repair |
Fan of the S-10
Re: Heater Core?
You can always bypass it until you get more time..........
Ive done this on the 4x4 89 Blazer I just got,I'll just fix it later. |
Re: Heater Core?
Thats the cause why it is broken! By driving with the truck, the engine moves a bit to the side. Then these tubes moves also, and the metal at the heatercore will brake after a time. So after removing the core, fix them!! Changing wasn't a problem for me, just 1 hour ![]() |
The Masked Magician
Re: Heater Core?
How is it supposed to be fixed?
Re: Heater Core?
There is a small metal that fixed the two pipes of the heatercore to the side of the heating-case / ac-case.
It isn't easy to describe it, but i try to take a picture tomorrow. |
The Masked Magician
Re: Heater Core?
yea if you can that would be great
Re: Heater Core?
Thats it.
It looks like a double U with a fixing screw between the U's. |
Re: Heater Core?
yea baron thats the heater core and they spring leeks every now and then either bypass it by running the pipe from the motor to the radiator(you'll hate yourself later) or replace it i think its only $30 at the zone
side note: you couldnt have spent 3 seconds of video time to reveal what was making all that noise under the hood! |
The Masked Magician
Re: Heater Core?
Why would I waste valuable video showing a stock 2.8 with a leaky carb gasket, hence why it idles like that.
Re: Heater Core?
"valuable video" sorry i didnt realize video time cost anything
Re: Heater Core?
Mine crapped out late last night, and I noticed the coolant on the way to work this morning. I plan to replace it myself, but I really don't have the time in this next week or so. I don't really feel like skipping my trip back home for Labor Day, or biking to work all week! |
Re: Heater Core?
Okay, I looked under the hood more at lunch. From what I can tell, the two hoses that Red Baron showed in his pictures are the inlets for the Heater Core?
To bypass the heater, all I would need to do then is run a hose from the back of the intake manifold, and up to the radiator? I'd find something to plug the heater core hose inlets too of course. I will end up replacing it, just not immediately. |
#24 |
Re: Heater Core?
Yes, you can o this.
Or you just disconnect the two tubes and connect the two tubes that goes in the heatercore with a small pipe. So the coolant will no more goes in the heatercore. |
#25 |
Re: Heater Core?
yes contra forget blockking off the core just run from the intake to the radiator, i think one of the hoses is long enough. just replace them when you fix the core
#26 |
1st gen rockn
Re: Heater Core?
The only bad part is even though you by pass the heater core there is still a lot of fluid inside of it thats still going to drip into your carpet.. I just replaced the heater core in mine without taking the dash out of it, It's a pain in the arse but as long as you take the glove compartment out like noted in the thread it's a hell of a lot easier then taking out the dash! ![]() |
#27 |
Re: Heater Core?
#28 |
Re: Heater Core?
Thanks for the info guys. This will atleast make 'er driveable til I have time to replace the core. Heat is kinda necessary in WI so it'll have to get done! |
