Gas tank removal? - S-10 Forum
post #1 of 22 Old 03-16-2006, 07:08 PM Thread Starter
not from canada
Canada Dry's Avatar
User is: Canada Dry is offline
Gas tank removal?
Hello,
My gas tank is becoming my worst nightmare, i am going to have to take it off to have a closer look at the hole in it. Has anyone ever taken a 1st gen gas tank off? I have an 83' if that helps at all. Do you think chiltons repair manual will cover this?
Thanks alot,
CD
post #2 of 22 Old 03-16-2006, 07:13 PM
ΜΟΛΩΝ ΛΑΒΕ!
1fast4by's Avatar
User is: 1fast4by is offline
Send a message via AIM to 1fast4by
Re: Gas tank removal?
its real simple, 2 straps, 3 bolts around the filler neck. and some wire harnesses
"The police cannot protect the citizen at this stage of our development, and they cannot even protect themselves in many cases. It is up to the private citizen to protect himself and his family, this is not only acceptable, but mandatory."
-Jeff Cooper
Ban gun free zones!
1fast4by is offline
post #3 of 22 Old 03-16-2006, 07:16 PM Thread Starter
not from canada
Canada Dry's Avatar
cool...as soon as its done leaking all over my garage and stinking up my house I can get to it
post #4 of 22 Old 03-16-2006, 07:44 PM
ΜΟΛΩΝ ΛΑΒΕ!
1fast4by's Avatar
I take it that its full huh
That sucks man, been there.
Fuel pump + full tank of gas = no fun
-Jeff Cooper
Ban gun free zones!
1fast4by is offline
post #5 of 22 Old 03-16-2006, 09:00 PM
Project Ol' Skool
LowEmotions's Avatar
User is: LowEmotions is offline
Send a message via Yahoo to LowEmotions
Dont Siphon it out with your mouth. i did that once, i learned gas dont taste as good as it smells
I Got Rid Of My Wife And Bought My Truck...
Best Thing I've Ever Done!!!
post #6 of 22 Old 03-16-2006, 09:27 PM Thread Starter
not from canada
Canada Dry's Avatar
i dropped a half gallon all over my hair and face on accident cause someone scared me in the woods....i had to crawl to the nearby lake in my underwear and blindly jump in
post #7 of 22 Old 03-17-2006, 09:22 PM
User is: jimluc is offline
Hello,
Thanks alot,
CD
Getting above the gas tank to remove the fuel lines is a real pain. It's alot easier to remove the gas tank when the bed is off. Plus,you can inspect the lines and your sending unit and replace them alot easier if they need to be replaced. Chilton will cover the gas tank removal, too.
jimluc is offline
post #8 of 22 Old 03-17-2006, 09:55 PM
mabru's Avatar
User is: mabru is offline
Just a suggestion, but if your tank is leaking your better off just replacing it instead of trying to fix the old one....won't be long and you'll probaly spring another leak somewhere else on it, and your back at square one. The peace of mind is worth the cost of a new tank imo.
-1992 S10 reg cab, short box, 383 in the works
-2005 GMC Jimmy 4x4, 5" BDS, 31x10.50 BFG AllTerrains
mabru is offline
post #9 of 22 Old 03-20-2006, 08:36 PM
LilJohn198807's Avatar
User is: LilJohn198807 is offline
Send a message via AIM to LilJohn198807
replace it and it is easyer if u have time and space to take the bed off....
post #10 of 22 Old 03-20-2006, 10:25 PM Thread Starter
not from canada
Canada Dry's Avatar
hmm I never thought I would have to remove the bed, I suppose I should buy the chilton repair manual for the bed removal as well. Ill keep you updated.
post #11 of 22 Old 03-21-2006, 05:44 PM
MiNi tRucKiN' oN A buDgET
freestylebikerguy's Avatar
User is: freestylebikerguy is offline
Send a message via MSN to freestylebikerguy
bed removal is easy. 6 bolts (possibly 8) and u can see exactly where they are if u crawl underneath. then u have to remove 3 bolts outta the filler neck (inside gas door) and the harness for the taillights in the back, should be somewhere around the back of the driver side framerail. then get a buddy or 2 and pull the box off.
post #12 of 22 Old 03-22-2006, 02:31 AM
life begins @ 20 psi
SY2932's Avatar
User is: SY2932 is offline
You don't have to even lift the bed off the truck, just remove the bolts on the driver's side of the truck and loosen the ones on the passenger side and tilt it up:
While I have it lifted up, I have someone shove a jackstand between the bed and frame to hold it up. Plenty of room to to get the fuel sending unit. I have replaced over a dozen fuel pumps myself. Last year the fuel pump went out in my S10 and it took my bud and I thirty five minutes start to finish to swap it out. I had to replace my tank his past fall due to rust pin holes. I patched it with Permatex radiator/gas tank epoxy and that bought me about half a year. Ended up buying a plastic gas tank through JC Whitney so that I never have to worry about rust again. Two tips:
1. If you get another tank, you will need to get a new fuel sending unit lock ring or cam. It's the metal ring that holds the fuel sending unit in the tank. Some part stores carry them in the "help" section. If you can't find one, you will have to go the "stealership" part number is #251-24032 and the price will be around $5. When you install that new lock ring, GREASE the living snot out of it so that it doesn't rust to pieces like to old one did. When I put my new tank in last fall, the lock ring still looked brand new and it came right out with no problems.
2. If you have a full tank of gas like I did when I had to replace my tank, you've got a problem. You need to get all that gas out. The easiest way to do it is first disconnect the fuel lines. Do yourself a BIG favor and draw a picture and/or label the lines so that you remember where they go. Connect a short length of hose to the outlet side of the pump which will be the line closest to the cab. Run the other end of the line into a gas can(s). Then disconnect the wiring harness that goes to the fuel pump. Take a jumper wire and connect one end to the positive terminal on your battery and touch the other end to one of the leads in the plug (there are two) on the fuel pump and it will pump all the gas out. It goes lots quicker than you think it would. Only took me about three minutes to pump out nineteen gallons of gas. HTH's
Mike Campbell
1991 4.3 TURBO V6 SYCLONE
Administrator on syty.net
My Gallery
SY2932 is offline
post #13 of 22 Old 03-22-2006, 09:41 AM
User is: s15mrteaz is offline
there is 4 bolts on the outside of the frame that hold the gas tank in ,
if you remove the bolts the whole gas tank assembly will lower down,
remove lines and pull out from under the truck,
then you can remove the straps from around the tank , when it is out from under the truck
in the picture above with the bed tilted( is a great idea also), you can see the upper bracket that the straps go to, that is part of the assembly that will come out when you undo the fore mentioned bolts.
post #14 of 22 Old 03-22-2006, 07:17 PM
Registered Asshole
crazy91s10's Avatar
User is: crazy91s10 is offline
Send a message via AIM to crazy91s10
like they said. easier to unbolt the bed and get to it. saves A LOT of headaches with those rubber lines!
post #15 of 22 Old 03-23-2006, 10:31 PM
m007gunit's Avatar
User is: m007gunit is offline
Send a message via AIM to m007gunit
I paid $80.00 for my tank on e-bay
post #16 of 22 Old 03-29-2006, 05:15 PM
Comitted Suicide
YellowDime's Avatar
User is: YellowDime is offline
when i did mine i dropped my tank and then extended the rubber hoses another foot and a half which made it much easier to install afterwards, i hooked everything up while the tank was on the ground and raised it up, the only bitch thing was the filler neck
-Robert-
1999 CanOBeer - Daily Driver
1989 Honda CBR 600 Hurricane - Resto Project
post #17 of 22 Old 04-01-2006, 07:13 PM Thread Starter
not from canada
Canada Dry's Avatar
Well I just ordered the gas tank and anit-squeak kit from LMC Truck. I will take a few pics of installation when it gets here. ( I cant believe I paid 100 dollars for tank )
post #18 of 22 Old 04-01-2006, 08:04 PM
itzmeto's Avatar
User is: itzmeto is offline
i had a hole in my first gen....****in u got an 83 i think they got smaller takes then the 85+....not sure.....when your tanks almost empty crawl under and weld it up....j/k....i bought a dec. gas tank for 5 bucks...
itzmeto is offline
post #19 of 22 Old 04-01-2006, 09:47 PM Thread Starter
not from canada
Canada Dry's Avatar
ha, well I dont know of any junkyards around here...so im stuck buying online and autozone
post #20 of 22 Old 04-05-2006, 07:51 AM
02 shortbed owner
dick verde's Avatar
User is: dick verde is offline
i wouldnt ever buy a junkyard tank unless you plan on having it boiled out and recoated, most machine shops can do this for around 50ish dollars
No ,my S-10 isnt bagged, 5/5 static.
post #21 of 22 Old 03-07-2013, 10:26 PM
User is: Morbugs is offline
bought a new metal tank from Oriellys 125 plus straps plus new pump plus sending unit and filter, need to replace all fuel lines as they are rusted terribly - I had to be towed home yesterday as the line just blew leaving me out there
1991 S10 reg cab long bed 4.3 2WD
Morbugs is offline
post #22 of 22 Old 03-07-2013, 11:44 PM
S10's-R-Us
Lowl!f3's Avatar
User is: Lowl!f3 is offline
Don't waste your money on those books for this simple stuff.
Pull your bed, way easier to get to the tank to see the real issue. You might can even fix it as well. Depending on if all it needs is the rubber o ring around the sending unit.
Lowl!f3 is offline
