front tilt hood - S-10 Forum
post #1 of 18 Old 09-16-2006, 09:48 PM Thread Starter
fmevans's Avatar
User is: fmevans is offline
Question front tilt hood
Got this done today. Hood won't latch. I'm guessing I need to adjust my hinges. Any suggestions?
ID:	85585   Click image for larger version
ID:	85586   Click image for larger version
fmevans is offline
post #2 of 18 Old 09-16-2006, 10:08 PM
94 s10 in progress
FxsX24's Avatar
User is: FxsX24 is offline
Re: front tilt hood
doubles as a fold out table
FxsX24 is offline
post #3 of 18 Old 09-16-2006, 10:23 PM
DOOR'D FOR HER PLEASURE!
Slappy McNasty's Avatar
User is: Slappy McNasty is offline
Re: front tilt hood
is everything lining up? striker and spring??? does it look like it did b4 you suicided it? (when closed) or is it off centered? check, and triple check to see if its centered, adjustments will help....
post #4 of 18 Old 09-16-2006, 10:28 PM Thread Starter
fmevans's Avatar
Re: front tilt hood
kinda feels like the hinges are keeping it from closing all the way. kinda like i got a trunk full o crap and it wont close.
fmevans is offline
post #5 of 18 Old 09-16-2006, 10:50 PM
Re: front tilt hood
can u post a pic of it closed or as close as it can go? sounds like you may have to drop the hinges a tad. you can insert washers between the hinges and the fender to achieve this... pain in the heiny but its werth it in the end....
post #6 of 18 Old 09-16-2006, 11:04 PM Thread Starter
fmevans's Avatar
Re: front tilt hood
this is the best shot i can get right now. I have time to suicide the hood but don't have time to change the burnt out bulb on the porch. lol
fmevans is offline
post #7 of 18 Old 09-16-2006, 11:07 PM
Re: front tilt hood
possible pic of the hinges and how they are installed? im thinking you bolted them to the top off the inner fender "lip" and not under ? ? ? hhhmmm, even then you still have like 3/4" and that wouldnt cause all that. is it hitting the computer, radiator cover, cooling lines, sometimes the crossbar hits things that may be it as well
post #8 of 18 Old 09-16-2006, 11:09 PM Thread Starter
fmevans's Avatar
Re: front tilt hood
umm ... ha i bolted them to the top. lol they should be on the bottom huh?
fmevans is offline
post #9 of 18 Old 09-16-2006, 11:17 PM
Re: front tilt hood
on my 02' dime, yeah that gives u alittle more room bro. try flippin em and see wut happens
post #10 of 18 Old 09-16-2006, 11:19 PM Thread Starter
fmevans's Avatar
Re: front tilt hood
i'll try in the morning and let ya know what happens. I hope it works cuz i gotta drive this thing to work monday.
fmevans is offline
post #11 of 18 Old 09-17-2006, 12:22 AM
former owner
98SS's Avatar
Location: north of Motor City ... formerly near Memphis
User is: 98SS is offline
Send a message via AIM to 98SS
Re: front tilt hood
Are those the Le Sabre hinges people say to use? I need to get some of those.
- Tim -
1998 S10 LS - stock, lemon - gone
1998 S10 SS - bagged, shaved, etc. - gone
2005 Civic
2010 Equinox
98SS is offline
post #12 of 18 Old 09-17-2006, 12:04 PM
AL4X4S10's Avatar
User is: AL4X4S10 is offline
Send a message via AIM to AL4X4S10
Re: front tilt hood
I have a set of these that I am 99.9% sure i am not using, email me for more info/pics
Thanks,
AL
1983 S10 P/U 355/350
1998 ZR2 extcab
2000 Devile
2000 Astro AWD
2002 ZR2 Blazer
AL4X4S10 is offline
post #13 of 18 Old 09-17-2006, 12:12 PM
BLACK DEATH
PYRO319's Avatar
User is: PYRO319 is offline
Re: front tilt hood
in the first pic you posted I can see there's one thing that you missed doing. In the how-to on the forum for suiciding the hood it show's to cut the stock hood hinge (which becomes the rear latch
This is a pic of how the stock hinge should slip back into the stock bracket after it s cut. this will hold the hood down.
PYRO319 is offline
post #14 of 18 Old 09-17-2006, 01:19 PM Thread Starter
fmevans's Avatar
Re: front tilt hood
the first pic. i hadn't cut them yet. I think i cut them kinda short. i got the hood to close by mounting the hinges under the lip but it sits high up at the cowl. I'm either gonna weld the tabs back on and recut or just go to the junk yard and get another set of the stock hinge brackets and recut those. i still need to tweak the alignment but it closes now.
fmevans is offline
post #15 of 18 Old 09-17-2006, 01:21 PM Thread Starter
fmevans's Avatar
Re: front tilt hood
i guess i just got into a hurry to get it done and ran into more problems than i needed to. It pays to take your time.
fmevans is offline
post #16 of 18 Old 09-18-2006, 09:37 AM
User is: Telco is offline
Re: front tilt hood
Anyone that is using this, is it any more difficult to work on the engine with the flip forward hood? Thought about doing this so as to have a hood that can't be opened by the wind when driving fast (later, when the 2.8L is gone) but I'm concerned with engine access. The other option is to pin the hood. Thanks.
Telco is offline
post #17 of 18 Old 09-19-2006, 09:40 AM Thread Starter
fmevans's Avatar
Re: front tilt hood
to me it's easier to work under the hood with it tilted.
fmevans is offline
post #18 of 18 Old 09-21-2006, 12:18 PM
mr. killyoass
killyoass's Avatar
User is: killyoass is offline
Send a message via MSN to killyoass
Re: front tilt hood
yep
