fikrewall water leak onto floorboard when it rains
Old 09-18-2008, 02:36 AM   #1
easterwabbit
fastr68's Avatar
fastr68 is on a distinguished road
have a bad water leakin coming from somewhere near the fuse panel
when it rains
fills the floorboard full of water
anyone know a common issue here wit these trucks that causes this ?
currently my cowl panel under the wiper arms is removed
would this alone cause this leak on these trucks >?
i really cant see exactly how and where the water is getting in other than its somewhere near the fuse panel
and thats all i can tell
thanks
Old 09-18-2008, 03:07 AM   #2
doing it for mom
MadMikeZ28's Avatar
MadMikeZ28 can only hope to improve
Re: fikrewall water leak onto floorboard when it rains
The windsheild may have a leak in it somewhere. The water can cling to edges and run all the way across and end up anywhere. Also since your cowl is off check and make sure its not plugged with dirt and leaves on both sides. Should be draining down at the very bottom from behind the fenders.
Old 09-18-2008, 07:42 AM   #3
Sucking dick while being Banned
SH-60B can only hope to improve
Is this the POS that shakes when you drive it? Drill a couple holes in the floor and call it a day. It's fast and easy. So easy, even a caveman can do it.
Old 09-18-2008, 03:52 PM   #4
87wildside's Avatar
87wildside is on a distinguished road
There is a drain on each side under the cowl. They plug up even with the black plastic piece under the cowl in place so with it removed it would just add to the problem. As MadMike said check to see if that's clogged. The drains are about level with, and slightly forward of, the lower hinges.
Old 09-18-2008, 04:32 PM   #5
easterwabbit
fastr68's Avatar
wow... why are you such a dick ??
chill out man.. seriously.. i didnt do a damn thing to you...im tired of this crap from you. if i wanted ot be treated this way then id call up an ex-g/f...
dick :O
you should not be replying in such a manner. if youre going to be nothing but rude and unhelpful then why evne reply at all ?
some ppl... damn..
thank you to mike and 87 for being MATURE and HELPFUL with good useable info
i knwo my windshield has a leak in the top middle
so maybe thats whats doing it
hmm
i appreciate it
Old 09-18-2008, 05:04 PM   #6
easterwabbit
fastr68's Avatar
ok i just figured it out.
i just dumped gallon of water on the cowl and it leaked inside.
traced it up to the steering column firewall seal.
someone unbolted it in the past all the bolts are missing
hum....
thanks
Old 09-18-2008, 06:06 PM   #7
hum....
thanks
hum...
um...
maybe
that's why....
um...
the
P.O.S....
SHAKES!!!!!!!!!!!!
Stupid...
umm...
DICK.
Old 09-18-2008, 09:46 PM   #8
1st Gen Mod
fetuss10's Avatar
fetuss10 is on a distinguished road
quit spacing out your posts everyone!
Old 09-19-2008, 12:49 PM   #9
I Rather Be Wheelin'
ChrisInVT's Avatar
ChrisInVT is on a distinguished road
hum...
um...
maybe
that's why....
um...
the
P.O.S....
SHAKES!!!!!!!!!!!!
Stupid...
umm...
DICK.
HAHAA
You know
you
might
be
on to
something
there!
Page generated in 0.11760 seconds with 11 queries
