Electrical issues Help PLEASE
I have an 87 S10 pickup with a 2.8R throttle body. I thought I had it diagnosed down to a fuel pump. Friday I was driving and it just shut off. I still have spark, jumped the fuel pump relay and nothing spray gas in the throttle body and it starts. So I put a new fuel pump in, but apparently I have an electrical nightmare on my hands. EVEN WITHOUT THE KEY EVEN IN THE IGNITION the ECM-B fuse blows. According to the scimatics a shop gave me; on that fuse is, Fuel Pump, Fuel Pump Relay, Oil Pressure Switch and the ECM. Except for the ECM have unplugged all of those and traced every wire that I physically could. All the wires look to be in good shape, nothing is brittle, cracked, chaffed or otherwise damaged. can someone please help me.
Thanks Eric |
Local Tech
Re: Electrical issues Help PLEASE
its hard to pinpoint without seeing, but ur first step would be to start unplugging items on that circuit (one by one), and after each one is unplugged, check if it still blows the fuse..... when u unplug the faulty part of the circuit, the fuse wont blow out..... theres a starting point at least..... goodluck, and if you need schematics or whatver, pm me, i run a shop and have access to whatever
I already unplugged one by one and with all of them unplugged it still blows I do have schematics that a local shop gave me I believe that since the truck was running PERFECT almost too good right before it shut off it almost has to be in the computer.
doing it for mom
do you have any buddy's that live near buy with the same truck that you might be able to use there ECM. if you unplugged everything but the ECM then that would be the first thing you should probably rule out.
and checked resistance |
doing it for mom
One from a blazer should work as long as it of the same powertrain. But if you had it unplugged and the fuse still blew then it would be something else.
There is a wire that goes from your firewall to your starter. That wire has been burned through because it touched the manifold. check that wire. it happened to me a year ago
I haven't had the time to pull the computer to unplugged it to check
Like I said before the truck was running perfect without ANY problems of any kind and than out of nowhere it just shutoff and the only circuit I have problems with is that one circuit.
I unplugged the computer and now it isn't blowing fuses. I just didn't have time to do that yet; I work weird hours. The good news is I work for Advance Auto Parts and the new compute will only be about $80
4x4 v6 blazer
Yes... those are my feet
I had the same problem not too long ago... Was on my way to work, turned a corner, and my truck just shut off... I blew 4 fuses unplugging stuff, and then it started working all of a sudden again... never had an issue again...
