Door sagging (pics) - S-10 Forum
post #1 of 11 Old 07-12-2009, 04:09 PM Thread Starter
User is: QQJJz is offline
Door sagging (pics)
This happened a while ago actually. The driver side door sags and its gotten to the point where I have to have the window down just to close it (pulling on the door from the middle) because if i use the inside handle I keep adding to the already ripped damage due to having to close it harder than normal. The hinges are intact (upper and lower) but because the door sags it has damaged the solenoid that is used for the keyless entry feature. It WILL close and latch properly if I am closing the door from the outside or close it hard from the inside.
This is the top driver side door hinge on a Chevy S-10 1997 by the way.
What I need to know is there a kit of parts or something similar I can use to get this door back on track and good to go myself or would some pros at a body shop have to get in on this? Here are some pics to help describe whats going on:
This is the passenger side door. It's just fine.
This is the driver side door. Notice what has happened.
This is driver side at another angle.
Suggestions? The spring and the part it sits on fell out when the door busted a while back and I could never find where the parts went..probably down the gutter that was nearby.
Thanks in advance guys.
QQJJz is offline
post #2 of 11 Old 07-12-2009, 04:12 PM
lurch's Avatar
User is: lurch is offline
Re: Door sagging (pics)
i had the same problem on my first gen all i did was weld the door pin holes shut and redrilled them put new pins in and never had a problem since then
1st gen long bed
~ phantom grille ~ BAGGED
NATS STAFF 05,06,07,08,09,10
RIP Dave "Loenuff" Swanson 1966-2007
www.stl-sseries.com
lurch is offline
post #3 of 11 Old 07-12-2009, 04:13 PM
No longer a pizza tech.
90blueS10's Avatar
User is: 90blueS10 is offline
replace the hinge pins
Ryan
90 2.5 5 speed, bag project
01 Jimmy 2dr 2wd daily driver
post #4 of 11 Old 07-12-2009, 04:27 PM
weezle29's Avatar
User is: weezle29 is offline
advance sells the springs through dorman. put a set of door hinge pins in and the spring and you should be ok
weezle29 is offline
post #5 of 11 Old 07-12-2009, 05:07 PM Thread Starter
The bushing that the metal arm pushes against due to the spring being behind it is completely busted out. Would that be included in a set of door hinge pins?
QQJJz is offline
post #6 of 11 Old 07-12-2009, 05:18 PM
User is: beedle4 is offline
No thats a diff kit
beedle4 is offline
post #7 of 11 Old 07-12-2009, 05:20 PM Thread Starter
Originally Posted by beedle4 View Post
No thats a diff kit
I'll probably need em both then. What would that kit be called?
QQJJz is offline
post #8 of 11 Old 07-12-2009, 09:18 PM
User is: MadMikeZ28 is offline
Roller detent. I never had to find one of those for a S truck but have seen them before in the "Help" sections of auto parts stores.
You just grind off the top of that pin and knock in out. Then the new one installs and uses an allen bolt and washer to hold it in.
But even if you don't find one of those do replace you pins and bushings!
If it has not already happened the hole will get worn out then it will need to be welded and redrilled. The bushings are press fit and if a new bushing just falls right in then the hole is worn. Also with the door sagging its hard on the latch and you will end up screwing that up and having to replace that as well.
If I acted like some of the people here do and ran to someone when ever my feelings were hurt I would have been called a sissy and then ridiculed for that as well. I suppose I just grew up in a time when we were all tougher and turned out to be men and women instead of staying crying children.
post #9 of 11 Old 07-12-2009, 09:54 PM Thread Starter
Sounds good. I'll probably get both doors done just for the preventative. Though this kind of work is out of my league for modding my truck so if I were going to leave this to some pros, what specifically would I need to tell them to do?
Replace the door hinge pins and bushings and the springs. Redo the pin holes and use a modified roller detent? Sound about right? Just gotta make sure.
QQJJz is offline
post #10 of 11 Old 07-12-2009, 10:29 PM
If they are truly pros you should only need to tell them the door is sagging. Thats how it was for me and I could figure out what it needed. Tell them it needs pins and bushings and a roller detent and spring is missing.
A pro should be able to know if a hole is enlarged and needs welding and resizing.
post #11 of 11 Old 07-12-2009, 11:28 PM Thread Starter
Ok I thought so. Just wanted to make sure I understood it as well. Been a big help guys, love this forum
QQJJz is offline
