defrost and vents not working for a/c and heat... - S-10 Forum
post #1 of 10 Old 09-16-2008, 09:29 AM Thread Starter
BIGT94z's Avatar
User is: BIGT94z is offline
just blows out the bottom vents. anyone have any idea's?
96 formula ~frank~ 12.251 @110.22
01 s10 ~dd~
BIGT94z is offline
post #2 of 10 Old 09-16-2008, 02:14 PM
slowteg97's Avatar
User is: slowteg97 is offline
Re: defrost and vents not working for a/c and heat...
yea check you vaccum supply lines that control the actuator sometimes they crack or even pop off there should be one just above the gas pedal to the right to give you an idea what your lookin for my truck has the same problem only blow through the floor vents barely through the dash and defrost vents. im just to lazy
post #3 of 10 Old 09-16-2008, 03:56 PM
I Don't Fear DEATH
specter692000's Avatar
User is: specter692000 is offline
got the same problem now i know how to fix it thanks slow
post #4 of 10 Old 09-18-2008, 12:58 AM
i saw what you did there!
fast68chevy's Avatar
make sure that the vacuum hose under the hood that runs to the passenger side to the heater system through the firewall is connected to the intake manifold vacuum still
this is main vacuum source to the heater control panel
and positions will not change without it
if its connected then the door in the heater box may be stuck
or the panel switch may be broken
or the actuator may be bad yes
most of the time its the vacuum hose thats not connected under the hood though
good luck
post #5 of 10 Old 09-24-2008, 07:25 PM
User is: injunjoes is offline
might not be very common but on mine it was a suction block right behind the heater controls etc, think the part was $14, that was after i took the dash out checked every vaccuum line etc 3 times and it was the stupid little piece that coulda been fixed in 10 min lol. but isnt that the way it always goes
post #6 of 10 Old 09-24-2008, 09:42 PM
User is: MadMikeZ28 is offline
Usualy if you have a vacuum problem it will blow out the defrost only as a default. In the heat and a/c position though it never is supose to blow out the defrost vents. Heat will blow out the floor and a/c will blow out the front vents or floor and front in Bi-level.
So if you do not get ac/ out the defrost vents don't panic. You're not supose to
If I acted like some of the people here do and ran to someone when ever my feelings were hurt I would have been called a sissy and then ridiculed for that as well. I suppose I just grew up in a time when we were all tougher and turned out to be men and women instead of staying crying children.
post #7 of 10 Old 09-25-2008, 04:01 PM
I Don't Fear DEATH
any clue as to why i only get it through on the floor even in the defrost position i dont have a/c in my truck can factory with out it an and i took out the controll panel and ran the switches up and down and on the htr vent and defrst side there is hardly any resitance behind it like there is when i go from cold to heat can anybody help me out with it
post #8 of 10 Old 09-25-2008, 06:24 PM
slowteg97's Avatar
yo i know exactly what ur sayin i have the same problem, im wondering if we should change that part that injunjoes suggested. i mean for 14 bux it cant hurt ya know????
post #9 of 10 Old 09-25-2008, 08:59 PM
If Injunjoes Is talking about what I think he is that could very well be why its stuck at the floor.
Pull out the unit so you can see the back side. Right where all the vacuum lines are there is a part that slides as you move the selector. It will rotate the vacuum selector. Some times the small pin will break and as you move the lever you will see that the selector does not rotate for the vacuum switch.
post #10 of 10 Old 09-25-2008, 09:12 PM
Maybe this will help some. Can't seem to find the rest. Garage is a mess!
