cruise control
Old 07-13-2008, 05:57 PM   #1
Truck #121616
Golana's Avatar
Golana is on a distinguished road
cruise control
hey guys, i found a 2.8L auto blaze with C/C and i pulled the module, the C/C computer, and the DRAC module, all the wiring and vacuum hoses.
the only thing i couldnt get was the magic wand on the steering column... how do you remove that?
also, will this C/C setup work for a 4.3L or v8?
Old 07-13-2008, 06:33 PM   #2
doing it for mom
MadMikeZ28's Avatar
MadMikeZ28 is an unknown quantity at this point
Re: cruise control
The CC should work. It does not know engine size. To get the magic wand all you do is pull and it cob]mes out of the wiper switch. then there is the wires that need to be fedd through. They are thin enough and should come out with no problem. I have done it before. Fishing them down into yours might be a little trouble though.
Old 07-13-2008, 06:37 PM   #3
Truck #121616
Golana's Avatar
Re: cruise control
so i just grab the wand, and it pulls out? sounds a bit more involved than just that...?
Old 07-13-2008, 06:41 PM   #4
doing it for mom
MadMikeZ28's Avatar
Re: cruise control
Thats all that you need to do to get it out of the wiper switch. Then pull the wires through.
Old 07-13-2008, 06:42 PM   #5
Truck #121616
Golana's Avatar
Re: cruise control
crazy...
ill give it a try. i have 2 spare steering columns for my 83.
so what about the DRAC module? this one has totally different plugs than the one in my 92... this one has 1 plug for the CC and another for everything else... mine only has 1 wider plug... i could take it out for example...
Old 07-13-2008, 06:43 PM   #6
doing it for mom
MadMikeZ28's Avatar
Re: cruise control
Pull straight out. Trust me have I ever lied to you before?
Old 07-13-2008, 06:45 PM   #7
Truck #121616
Golana's Avatar
Re: cruise control
hahaa, i dont think you've ever offered me advice before, so thats a no :P
Old 07-13-2008, 06:47 PM   #8
doing it for mom
MadMikeZ28's Avatar
Re: cruise control
well see then Try it on one of your spare columns first. The shaft can break on the levers
Old 07-13-2008, 06:48 PM   #9
Truck #121616
Golana's Avatar
Re: cruise control
how hard am i supposed to pull?
Old 07-13-2008, 06:48 PM   #10
doing it for mom
MadMikeZ28's Avatar
Re: cruise control
Oh and I have responded to some of your threads. I think the latest was your turbo charged washer pump and squirters.
Old 07-13-2008, 06:49 PM   #11
doing it for mom
MadMikeZ28's Avatar
Re: cruise control
Just a good firm pull straight out.
Old 07-13-2008, 06:50 PM   #12
Truck #121616
Golana's Avatar
Re: cruise control
hahaa, yea i have yet to hook up the other pump. it works good though, that blaze pump is stronger than my stocker.
so what about the DRAC modules?
Old 07-13-2008, 06:57 PM   #13
doing it for mom
MadMikeZ28's Avatar
Re: cruise control
Its been a while since I pulled it all out of my mom's. I remember the C/C module under the dash, a brake switch and the unit under the hood.
Old 07-13-2008, 07:01 PM   #14
Truck #121616
Golana's Avatar
Re: cruise control
yup, i got all that good stuff only thin i am missing is the magic wand
Old 07-13-2008, 07:03 PM   #15
doing it for mom
MadMikeZ28's Avatar
Re: cruise control
None on any of those spare columns either huh
Old 07-14-2008, 02:00 PM   #16
Truck #121616
Golana's Avatar
Re: cruise control
anyone have a pinout for Cruise Control?
if not, ill just probe and figure it out myself. im pretty confident with GM wiring and colors, so it shouldnt be too hard, just thought i'd ask before i spend a day or so working on wires
the reason i ask is since GM never implemented the Cruise Control indicator light, im going to make the one in my digital cluster work.
Old 07-14-2008, 04:16 PM   #17
doing it for mom
MadMikeZ28's Avatar
Re: cruise control
Did you just need a schematic type of diagram?
Old 07-14-2008, 04:31 PM   #18
"The Recruiter"
jtcfanof3's Avatar
jtcfanof3 is on a distinguished road
Re: cruise control
LOL
Ya,fishing it into the column is gonne be the hardest part.
Heres what the "magicwand" looks like after its removed:
I would get ya the pinout of the DRAC,but Mikes gonna hook ya up with the same schematic I would read off of so..........
If ya break the one removing it,that one pictured above is for sale
Old 07-14-2008, 06:53 PM   #19
doing it for mom
MadMikeZ28's Avatar
Re: cruise control
Does this work for you? It is from a Camaro manual but should be the same. I like this type better than whats in my S10 manual.
Old 07-14-2008, 06:54 PM   #20
doing it for mom
MadMikeZ28's Avatar
Re: cruise control
UGH!
If that will work for you and you can not see it PM me an email and I will send the full size. I had to shrink that one.
Old 07-14-2008, 09:46 PM   #21
Truck #121616
Golana's Avatar
Re: cruise control
thanks for that schematic, its too small for me to read... could you email me the fullsize one?
cetus808@gmail.com
Thanks bro
Old 07-14-2008, 09:49 PM   #22
Truck #121616
Golana's Avatar
Re: cruise control
Quote: Originally Posted by jtcfanof3
LOL
hahaa, thanks bro, i did get it out just fine. i practiced on a few at pick n pull first. we were up in calgary anyways, so i stopped by, and grabbed what i could without tools. didnt take much of a yank hahaa, i got it out. there were about 3 others, but all the wires were worn through... the one ive got was about half worn through... im guesisng this is a common problem on these things... shitty... what can be done to prevent this?
Old 07-14-2008, 10:04 PM   #23
doing it for mom
MadMikeZ28's Avatar
Re: cruise control
email sent. It is inserted in the email an attached as well.
Old 07-14-2008, 10:05 PM   #24
Truck #121616
Golana's Avatar
Re: cruise control
for the schematic, i just gotta find out which wire turns on and is negative... the CC light on the dash is negative on, so ive gotta find a wire that is only negative when the CC is on... either that, or im going to have to go crazy and wire up my own thing for the CC light. i could do it, its just i dont want to modify the cluster if i dont have to
Old 07-14-2008, 10:23 PM   #25
doing it for mom
MadMikeZ28's Avatar
Re: cruise control
I see. And it looks like everything on the CC works with power. No switched grounds at all.
Old 07-14-2008, 10:43 PM   #26
Truck #121616
Golana's Avatar
Re: cruise control
yea, it appears that way... guess ill have to implement my own thing into the digital cluster. shouldnt be too hard, im just concerned with taking it apart all the time haha!
Old 07-16-2008, 08:34 AM   #27
Truck #121616
Golana's Avatar
Re: cruise control
Here is what i came up with. see the track about the middle, where its all scratched up? What i did was separate the Cruise Control light circuit from the rest.
This is what i had originally come up with... Soldered a couple wires onto the back of the board to run to a ground, and the grey wire in the Cruise Control circuit.
Yea, it worked, but it was a pain in the ass... i'd rather have it wired up into the main gauge harness...
So guess what i did :P i wired it into the main harness! see that wire there, i ran the (+) side of the light into the circuit for the Check Fluids light (that GM never implemented either). I had to isolate that circuit too (see the scratches just after the solder ball). What i actually did was cut into the board, just enough to cut through the copper track, then i cut about 1mm up the track, and peeled the copper up.
So this is how it works now. All wired into the main cluster harness! I also ran a ground from the CC Light pin to the main ground for the cluster. Just gotta run the yellow wire to the grey one on the CC harness, and im good to go!
Old 07-16-2008, 02:47 PM   #28
doing it for mom
MadMikeZ28's Avatar
Re: cruise control
Well you are a resourceful little dude aren't you. Good Job!
Old 07-16-2008, 04:09 PM   #29
"The Recruiter"
jtcfanof3's Avatar
Re: cruise control
All that for a light that shows your cruise is engaged!!
Well hey,I applaude your efforst!
Old 07-16-2008, 06:44 PM   #30
Truck #121616
Golana's Avatar
Re: cruise control
well, i wanted a cruise light... i wonder how many other people have it :P
besides, wouldnt you want a cruise light? hahaa, i cant wait to get this done and go for a cruise :P
Old 07-16-2008, 06:44 PM   #31
Truck #121616
Golana's Avatar
Re: cruise control
thanks bro, im very determined... if i want something, ill figure out a way to get it
Old 07-16-2008, 07:39 PM   #32
doing it for mom
MadMikeZ28's Avatar
Re: cruise control
As longas you got it might as well use it right.
Old 07-16-2008, 07:48 PM   #33
Truck #121616
Golana's Avatar
Re: cruise control
exactly.
i wrote a how-to on doing this, so easy
Old 07-16-2008, 09:44 PM
