clear headlight conversion ?'s
i want to do a blue healight bulb or hid conversion in my 88 s10. i want the housing to look stock so will either of these work?
http://www.stylintrucks.com/parts.aspx?category|category_root|-26=Lighting&category|cat_-26|181=Headlights&canned_results_trigger=&partid=5 31137 http://www.autobarn.net/helhigperhal.html also, what bulb should i run in these? im sure someone has done this and can chime in before i experiment myself ![]() Last edited by BIGT94z : 09-13-2008 at 01:57 AM. |
SoCal Football
Re: clear headlight conversion ?'s
I believe you'll find more info in the elec forum, but to
give you an idea, one option is convert from H6054 sealed beams to H4 bulb headlamps housings and then add a HID kit that is avail on eBay. Members over in the elec forum have given props to this one seller who has a kit avail for a 100.00 or so. It's been a while, but if you do a search you'll find plenty of info there. I believe most there have later model rides, but there are kits avail for 1st Gens. You listed the Hella HB2 lamp which is a first rate lamp and yes it will go right in. You will then have to come up with H4 bulbs. You may wan to update your wiring and get HD ceramic sockets for the bulbs if you want it bright to light up the road. I use Cibie E-Code 200mm lamps with Osram 85/80 H4 bulbs in mine. I updated the wiring to a system using relays and 10 gauge wire with indiv fuses and it lights up pretty darn bright at night. I don't use blue bulbs, but that's ones choice. HTH's. I'd stay away from the 19.00 dollar crap. Hella has been around a long time and is a quality lamp. Last edited by bg's : 09-13-2008 at 08:20 PM. |
SoCal Football
Here is another kit like the one you linked to from Autobarn.
The Hella lamp will accept 9003, H2 and H4 bulbs. http://www.rallylights.com/hella/200mm.asp If you wreally wanted blue and bright, you can go with the Hella Xenon 100/80W blue bulb. It should really throw out a beam, but you might get a ticket for them.. http://www.rallylights.com/hella/H4.asp |
im actually runnin those headlight housings in my truck those alone with the h4 bulbs that come with them where a huge improvement at night. the only down fall on these headlights is that they are not dot approved i had them in when i went through inspection and failed cause of it, so i just ran home and swapped my stockers back in and changed them back out once i got home. and just so you know hids will work well in those housings but hids are ment to be run in a projector style lens because it can focus the light from the bulb with these style housings the light kinda just goes everywhere alot of guys with civic does this and that is the result also you will run into the same problem they have where your high beam and low beam are in the same bulb so you will either need to buy the more expensive kit which allows you to still have high beams or you can just get the standard kit and you will have no high beam. heres the style kit you should be lookin for.
http://cgi.ebay.com/HID-XENON-CAR-KI...QQcmdZViewItem also be aware those cheap hid kits you see all over ebay like the one i showed you your gonna get what you pay for so dont expect the bulbs to last long. |
doing it for mom
I like the title, "Clear Headlight Conversion".........What color are you starting off with? I got OEM clear headlights!
