can firebird rims fit on a s10 - S-10 Forum
post #1 of 14 Old 10-13-2010, 05:32 PM Thread Starter
User is: mikedoe is offline
just want to know it u can put Firebird 16" rims on a s10 i know the back spacing on the front rims are different than the back but my truck is lifted up and need to take my 33's off and have a few set of 16" tires around and yes i know it will look stupid with Pontiac rim on a s10 but i do a good job at looking stupid so my truck will look it to
mikedoe is offline
post #2 of 14 Old 10-13-2010, 06:19 PM
hmmm...
spazattack's Avatar
User is: spazattack is offline
Re: can firebird rims fit on a s10
yeah, I think only the rears will fit properly iirc. So 4 rears would fit
1991 S10 2.8L Ext Cab 2WD
-Cameron
post #3 of 14 Old 10-13-2010, 06:35 PM
Registered Hoosier
Hoosier Rick's Avatar
a friend has trans am wheels on his 1st gen. fit on frt and rear.
2002 rcsb, 2.2 at, 267,000 miles
1967 C10
post #4 of 14 Old 10-14-2010, 08:08 AM
peace and big boobs to u
phantom_mia's Avatar
User is: phantom_mia is offline
is your truck 4x or 2x and what year trans am did they come off of, any picks?
mike
"primer express" 91 RCSB, 4.3 z, 3713 Edelbrock intake and headers, flowmaster exhaust, comp cams 266hr cam and roller tip rockers, ported heads, 3:08 rear. boss 338's 18x8 225/45/18 f 255/55/18 r
ADVANCED FORUM SEARCH
http://www.s10forum.com/forum/search.php
opinions expressed are my humble $.02 worth
post #5 of 14 Old 10-14-2010, 04:46 PM Thread Starter
my truck is a 85 4x4 the rims i am looking at r off a 88 formula
mikedoe is offline
post #6 of 14 Old 10-14-2010, 07:15 PM
Fronk-en-Steen
mostizzle's Avatar
User is: mostizzle is offline
the 16'' formula rims should fit a 4x4, they have the same BS as the 4x4's or close to it.
TelAmeriCorp
post #7 of 14 Old 10-14-2010, 08:17 PM Thread Starter
cool thanxs for the info
mikedoe is offline
post #8 of 14 Old 10-14-2010, 08:26 PM
hmmm...
spazattack's Avatar
right sorry, i assumed you were 2wd for some reason
-Cameron
post #9 of 14 Old 10-14-2010, 11:50 PM
Fronk-en-Steen
mostizzle's Avatar
if they're going on a 2wd then i think you need 1/4'' spacers it the front and like a 1 1/2'' in the rear or something like that for them to look right and not rub.
TelAmeriCorp
post #10 of 14 Old 10-15-2010, 05:36 AM
User is: AK99 is offline
The Formula 16's have different backspace front-rear. Only the rears are similar to a 4x4, but since the 4x4 has a wider track at the front it should work if you switch them around. Put the fronts on the rear and the rears on the front, should work out OK.
'91 S-10 Longbed
SGT in a rusty S10 wrapper, 4/3 drop, 350tbi/NV3500 coming soon
AK99 is offline
post #11 of 14 Old 10-15-2010, 09:55 AM
User is: 4 X 3 is offline
The rims will fit on your s10. Pontiac Firebird had no tire size option for the 16 in rims. 245/50's . . .with the 4 - 16's installed, the 4x4 gear ratio will have a slight signal change, but no problem. One of two concerns is the stud length and lug nuts. The standard studs will not give you a full stud thread. The standard nuts have a smaller bevel cone. Suggest that two longer studs be installed on front / rear and 20 lug-nuts with 'more-meat' secure the rims.
Note: The 245/50's mounted stick out a 'bit' and while they look good, each will be subject to introduce road debris to the lower panels.
''Thats the name of that tune''
4 X 3 is offline
post #12 of 14 Old 10-16-2010, 09:11 AM
ASE certified MasterTech
jtcfanof3's Avatar
User is: jtcfanof3 is offline
Send a message via AIM to jtcfanof3
Front backspacing specs 4.75
Rear backspacing specs 5.25
Formula Firebird wheels /\
4th gen wheels that fiit nicely on a 4wd has a 6.875 backspacing, so they will stick out past the fenders per these specs. Now these specs vary on wheel width, but stock 4wd S-Series has a 6.000 backspacing.
Stock 4wd wheel specs are 15x7, and formula wheels are a 16x8.
1989 Chevrolet Blazer 3.4
1989 Chevrolet Blazer 4.3 4x4
1989 Chevrolet Blazer 4.3 Edelbrock equipped
2003 Chevrolet S10 4.3
1999 Chevrolet S10 Xtreme 2.2
post #13 of 14 Old 12-24-2010, 07:24 PM
vvolkswaggn's Avatar
User is: vvolkswaggn is offline
Wink Re: can firebird rims fit on a s10
http://www.tacreationsusa.com/firebird_wheels.htm <---- best link there is to answer most questions about this firebird and camaro/TA wheel post.. i have a set of 91-92 Firebird optional rims "Gold" and painted them Metallic and both the same wheel backspacing on both front and back. and 5x4.75 Here is a link to my photo album showing you my 98 truck with the wheels on it. I have no problems with rubbing but the back wheels stick in a bit in my opinion.http://www.flickr.com/photos/volkswagenbus/4825864946/sizes/l/in/photostream/. I also have a different rearend in it 3.73 I ruduced the tire size down 10% and went wee a bit wider on the tire width. The truck seems to get better gas mileage, and im not sure why...any ideas? i live in Northwest-flatland Ohio and its an Automatic. I paid $400 for this truck, put plug wires on it and have driven it from ohio to Washington state all the way to maine. And i live in ohio, so its been back and fourth. I love My truck!
post #14 of 14 Old 12-25-2010, 08:44 PM
Fronk-en-Steen
mostizzle's Avatar
i almost bought a set of those a couple years ago but they were beat.
TelAmeriCorp
