Broken cab mount - S-10 Forum
post #1 of 6 Old 11-08-2009, 01:27 AM Thread Starter
K-Slice's Avatar
User is: K-Slice is offline
Send a message via MSN to K-Slice
Broken cab mount
So I just bought my S10 the other day, got a good look underneith and found the passenger cab mount is rusted through and broken.
Now my jimmy had this too but I just ignored it, but this truck I plan on keeping and want to fix it. To be honest I'm really not sure how cab mounts work or how to separate the body from the frame...
Hope someone here can help.
Thanks.
K-Slice is offline
post #2 of 6 Old 11-08-2009, 01:41 AM
little mouse on a scooter
Built2NV's Avatar
User is: Built2NV is offline
Send a message via AIM to Built2NV
Re: Broken cab mount
Its not too bad its just a lot of work. You need to take everything out. Brake booster, heatercore/blower box, all the vents system behind the dash, the dash, pull the carpet back and rip out all parts that connect to the pedal like the clutch, brakes, and accelerator cable. Steering needs to come out as well, disconnect fuse panel, etc. Its a lot of work but to remove the cab its just 4 bolts and pick it up lol.
Edit: Forgot front fenders, inners, and hood lol
Member of Bravada Grills Suck Coalition
Build Thread: Project Built 2 Envy
Built2NV is offline
post #3 of 6 Old 11-08-2009, 11:14 AM
ASE certified MasterTech
jtcfanof3's Avatar
User is: jtcfanof3 is offline
Send a message via AIM to jtcfanof3
Or you could just replace the cab mount. They sell them, I have an extra if you go that way. Check your floorpan as well along with the inner rocker panel, they may be rusted as well, if so then you have more work ahead of you because the cab mount is attached to the floor and rocker. DO you have access to a welder and or abilities? If not swapping cabs may be the way for you to go.
1989 Chevrolet Blazer 3.4
1989 Chevrolet Blazer 4.3 4x4
1989 Chevrolet Blazer 4.3 Edelbrock equipped
2003 Chevrolet S10 4.3
1999 Chevrolet S10 Xtreme 2.2
post #4 of 6 Old 11-08-2009, 05:29 PM
i saw what you did there!
fast68chevy's Avatar
ive had a few that were like this and i just let them go and they were fine.
even my 91 now has a rusted out broken pass side front mount
so common
the full size trucks were worse about this problem though.
by far
we always just jack up the cab and stick blocks between the cab and rame rail
i there is enough floor left anyways
sometimes there are no floors or supports left at all and the front the cab floats around
the steering column keeps the cab in place yay
driven many this way over the years
pedo bear avatar haha great
post #5 of 6 Old 11-09-2009, 12:08 AM Thread Starter
K-Slice's Avatar
Im not sure if its the "cab mount: that's broken.. I tried to draw what it would look like if it was new and the part that's rusted out is in red:
It;s like a piece of metal that sticks below the cab and is surrounded by bushings (i guess) and gas a bold through the middle..
The floor pan is decent, the top of tat bolt is just resting on the floor now since the other part rusted. It almost seems to me that if i could find something to inject that whole area with that would become rigid that it would hold good. I don't know what I'd use, some kinda plaster or something... Any idea for somwthing I could use for that?
I don't need this truck to be like new or ever real pretty. I just dont want it to die a premature death becasue of something stupid like this.
OH! And thanks for the help so far!
K-Slice is offline
post #6 of 6 Old 02-23-2010, 10:13 PM
junkyard dog
rusty7983's Avatar
User is: rusty7983 is offline
what holds the bolt in? is it a nut? or something special? i need to change my mounts and fix the drivers rotted floor. everywhere i look, there isn't a nut. how do i replace it?
