Blinking Parking Brake Light - S-10 Forum
post #1 of 26 Old 01-24-2010, 10:47 PM Thread Starter
FFAMatt
FFAMatt's Avatar
User is: FFAMatt is offline
I have a 1989 S10 4wd 2.8 5sp and the parking brake light in the dash is blinking. The light will do four short blinks then a long blink, then repeat. it does it whenever the truck is running. The parking brake hasn't worked on it since I got the truck six months ago. Would it be throwing a code that I need to check? I have no idea why it is on, just want to figure out if it is something I need to fix.
Trail Rig: 91 s-10 Blazer two door, "modified fenders" to clear 33s. SAS on the way!
Daily Driver/Tow Rig: 01 Suburban 2500. Pretty much stock for now...
Sold, trying to get back: Beater 89 S-10, 3.4 swap, modified 4wd, custom shortened flatbed, homemade bumpers
FFAMatt is offline
post #2 of 26 Old 01-25-2010, 05:06 AM
adamwilkes20's Avatar
User is: adamwilkes20 is offline
Re: Blinking Parking Brake Light
that is the way the RWAL tells you the code...when mine started flashing I just unplugged the module under the dash that is on the inside of the fender.
post #3 of 26 Old 01-25-2010, 09:59 PM Thread Starter
FFAMatt
FFAMatt's Avatar
What is the RWAL?
FFAMatt is offline
post #4 of 26 Old 01-25-2010, 10:44 PM
Rear Wheel Anti Lock
post #5 of 26 Old 01-25-2010, 11:39 PM
ASE certified MasterTech
jtcfanof3's Avatar
User is: jtcfanof3 is offline
Send a message via AIM to jtcfanof3
Jump A and H on the ALDL and watch the light for the code, report back.
1989 Chevrolet Blazer 3.4
1989 Chevrolet Blazer 4.3 4x4
1989 Chevrolet Blazer 4.3 Edelbrock equipped
2003 Chevrolet S10 4.3
1999 Chevrolet S10 Xtreme 2.2
post #6 of 26 Old 01-29-2010, 05:50 PM Thread Starter
FFAMatt
FFAMatt's Avatar
Which is port H? I've jumped A and B and I have no check engine light codes. What do I need to look at to check my blinking parking brake light?
FFAMatt is offline
post #7 of 26 Old 01-29-2010, 06:13 PM
watch the brake light...it will blink like it is doing now, count the # of blinks and that is the code...H is on the bottom row and starting from the left, it is the second one...
post #8 of 26 Old 01-29-2010, 06:14 PM
PROCEDURE:
Diagnostic Trouble Codes (DTC) 's can be displayed by jumping terminals "A" and "H" of the Data Link Connector and observing the flashing of the "BRAKE" warning light. This should only be done when the brake lamp is "ON".
The terminals must be jumped for about 20 seconds before the code will begin to flash. Count the number of short flashes starting from the long flash. Include the long flash as a count. Sometimes the first count sequence will be short. However, subsequent flashes will be accurate. If there is more than one failure, only the first recognized code will be retained and flashed.
NOTES:
DTC's 6, 9 and 10 will only turn the "BRAKE" lamp on while the fault exists. These are soft codes faults and can only be read with the Tech 1 scan tool.
Do not jump terminals "A" to "H" if the "BRAKE" lamp is not on. Jumping the terminals with the "BRAKE" lamp off will set a false DTC 9. This will turn the "BRAKE" lamp on and disable the antilock system.
  • 1, 11, & 12 ECU Malfunction
  • 2 Open Isolation Valve or Malfunctioning ECU
  • 3 Open Dump Valve or ECU Malfunction
  • 4 Grounded Antilock Valve Reset Switch
  • 5 Eccessive Actuations of the Dump Valve
  • 6 Erratic Speed Signal
  • 7 Shorted Isolation Valve or Faulty ECU
  • 8 Shorted Dump Valve or Faulty ECU
  • 9 Open Circuit to Speed Signal
  • 10 Brake Lamp Switch Circuit
  • 13, 14 and 15 ECU Malfunction
post #9 of 26 Old 01-29-2010, 06:28 PM Thread Starter
FFAMatt
FFAMatt's Avatar
I went through that procedure and it gave me four short blinks then a long blink, four short blinks then a long blink, and on
FFAMatt is offline
post #10 of 26 Old 01-29-2010, 06:41 PM
Then I suppose that would be code 5, excessive acctuations of the dump valve.....
post #11 of 26 Old 01-29-2010, 06:44 PM Thread Starter
FFAMatt
FFAMatt's Avatar
And what exactly does that mean, and how do I fix it? It just started blinking and I haven't noticed any differences in driving or stopping.
FFAMatt is offline
post #12 of 26 Old 01-29-2010, 06:45 PM
honestly man, like I said above...the RWAL is useless...I would disconnect the module and ride...
post #13 of 26 Old 01-29-2010, 06:50 PM Thread Starter
FFAMatt
FFAMatt's Avatar
What does it look like? Where is it in relation to the fuse panel?
FFAMatt is offline
post #14 of 26 Old 01-29-2010, 06:53 PM
under the hood next to the master cylinder, there will be a black box, should have two (IIRC) connectore plugged into it....
I have been running mine unplugged for a couple years now...and you will find a lot of guys on here foing the same.
post #15 of 26 Old 01-29-2010, 06:55 PM Thread Starter
FFAMatt
FFAMatt's Avatar
How is your fuel mileage? It doesn't have any ill-effects?
FFAMatt is offline
post #16 of 26 Old 01-29-2010, 07:16 PM
it doesnt affect fuel mileage at all...all that box is is like the brain for your RWAL...
post #17 of 26 Old 01-29-2010, 10:54 PM
jtcfanof3's Avatar
Yep, you have a code 5. My service manual right off the bat says to replace the valve assembly.
As stated before, RWAL is a waste, I mean ya it's OK if you lock up the rear wheels and they try to pass the front wheels, but generally in a panic stop the fronts wheels are what you still want to be able to control. SO yes the rear wheels will lose traction first because of inertia, but again you can steer into the skid, unless your fronts are locked up because you don't have all wheel ABS.
So in short, just unplug the module, unless you live in a state where you get tested for inspection every year and they require the ABS unit to function, then you will need to replace some parts.
post #18 of 26 Old 01-31-2010, 12:36 AM Thread Starter
FFAMatt
FFAMatt's Avatar
So I can just unplug the black module next to the master cylinder and trace the wires back to the originating location and take it all of/out and be perfectly fine?
FFAMatt is offline
post #19 of 26 Old 01-31-2010, 05:50 AM
For insurance purposes, I would leave it in there...just incase you need to hook it back up for something...
post #20 of 26 Old 02-16-2010, 10:27 PM
local engineer
bouchee2007's Avatar
User is: bouchee2007 is offline
Send a message via AIM to bouchee2007
hey guys not to thread jack but this is the only thread i found with a similar problem. my parking brake light blinks for 6 short 1 long, its a 91 4.3l as far as i know this truck never had abs. any ideas? and sorry to jack
Jeeps have become like purses they all look slightly different, and yet every one is the same.
:Sonomanclature
post #21 of 26 Old 02-16-2010, 10:31 PM
7 Shorted Isolation Valve or Faulty ECU...
You really dont have "ABS"...it is just RWAL and it was standard in all S Series trucks starting in 1989
post #22 of 26 Old 02-16-2010, 10:32 PM
jtcfanof3's Avatar
Did you jump A & H?
I do not know if they all had RWAL or not, but you will see a module next to the master cylinder, it sits sideway with two connectors on it, if you have this then that is the easiest way for me to tell you that yes you have RWAL.
Please respond back.
post #23 of 26 Old 02-17-2010, 12:14 AM
local engineer
yes i do have that unit, i always wondered what that was. and from the above posts there are no ill effects from removing it. thank you for the info .
:Sonomanclature
post #24 of 26 Old 03-16-2010, 08:05 PM
User is: BotterbrodtGE is offline
Sorry to Jack the thread also. Have a code six. Five short and one long. It says "erratic Speed signal. How can this be fixed?
post #25 of 26 Old 01-02-2016, 07:07 PM
alderfek's Avatar
User is: alderfek is offline
Send a message via AIM to alderfek Send a message via MSN to alderfek Send a message via Skype™ to alderfek
So, I have an 11 code. ECU malfunction. Which ECU? The main computer or the one next to the master cylinder?
It started tossing the code, acting like it was missing a few times and the started spark knocking very bad,would die as soon as I turned on lights or hit the brakes. Needless to say,a fun ride home.
Kirk
North of Mason, South of Dixon, 2nd star to the right.
1st Gen Jimmy GT build http://www.s10forum.com/forum/f20/pr...mmy-gt-510067/
alderfek is offline
post #26 of 26 Old 03-01-2016, 04:48 PM
User is: dspringer56 is offline
The one next to the master cylinder. Black plastic box 6 inches square, inch thick. Two wiring plugs facing rear. Rear wheel antilock brake computer comes standard on 1989 S10. In a fault the brake light comes on and stays on. If it's blinking it's stuck in the code reading mode. You can reset code reading mode by removing the fuse labeled "Brake" for 5 seconds.
You can read the codes by shorting A and H together on the ALDL connector with a paper clip. A is upper row far right. H lower row, second in from the left. Short those, turn the key on, and it starts blinking the code. Once in that mode it stays that way forever until you remove the brake fuse for 5 seconds. Haynes manual doesn't say it will stay blinking. Removing the fuse clears the trouble codes.
Mine was a code 7 faulty isolation or control unit. I checked the isolation valve by disconnecting it (tan/white wire going to front/rear proportioning valve right below master cylinder". Light should go off when unplugged from the switch. It didn't for me. So it appears to be the control unit.
Everyone says the RWAL is just about useless, which it probably is. So I simply disconnected the top connector from the controller, taped the openings to keep out water and dirt. Light went out. Brakes still work. Now the brake light is just a parking brake warning light. Legal requirement in Texas is that parking brake light works when pedal is depressed and no dash warning lights are lit. RWAL doesn't have to work but it will fail inspection if the warning light stays on.
