best way to lower - S-10 Forum
post #1 of 26 Old 03-28-2009, 09:20 PM Thread Starter
Ivegottastickwhatwhere??
kylers2k's Avatar
User is: kylers2k is offline
Send a message via AIM to kylers2k Send a message via MSN to kylers2k Send a message via Yahoo to kylers2k
best way to lower
can u flip the leaf springs?
and for the front whats the best way to go
okay i should rephrase
cheapest
i just dropped the 4 banger back in.. got a silverado im workin on and need a beater truck lol
sooooo i might just cut the springs.. bad idea??
kylers2k is offline
post #2 of 26 Old 03-28-2009, 09:31 PM
adamwilkes20's Avatar
User is: adamwilkes20 is offline
Re: best way to lower
cutting the springs is a bad idea IMO....do it right, there are other people on the road with you,wouldnt want you to hurt or kill somebody by taking shortcuts on your truck. Get some drop spindles, drop coils, and lowering blocks...they arent THAT expensive...
post #3 of 26 Old 03-28-2009, 09:42 PM
Freedom
Joker Relentless's Avatar
User is: Joker Relentless is offline
So are you dropping the silverado or another s10?
NEVER cut the springs on anything you're working on.
post #4 of 26 Old 03-28-2009, 09:42 PM Thread Starter
kylers2k's Avatar
how would cuttin the springs hurt or kill someone??
kylers2k is offline
post #5 of 26 Old 03-28-2009, 09:43 PM Thread Starter
kylers2k's Avatar
droppin the s10 liftin the silverado
kylers2k is offline
post #6 of 26 Old 03-28-2009, 10:13 PM
ASE certified MasterTech
jtcfanof3's Avatar
User is: jtcfanof3 is offline
Send a message via AIM to jtcfanof3
Cutting a coil only loweres the center of that coil,but by doing so you are allowing the the lower control arm to bottom out,if you were to hit a big bump it could cause you to lose control.Heating the coil is also a bad idea,it causes a moleculer change in the steel weakening it.Now you say,doesnt a drop coil do the same as what I stated above,yes,but the drop coil it stiffer progresivly which allows for the shorter distance too the bump stop,this is why 3 inch drop coils make or a harsher ride.
BTW,axle is already above the leafs,so no fliping there.But you can pull a leaf to gain about a 1.5 inch drop for free.
1989 Chevrolet Blazer 3.4
1989 Chevrolet Blazer 4.3 4x4
1989 Chevrolet Blazer 4.3 Edelbrock equipped
2003 Chevrolet S10 4.3
1999 Chevrolet S10 Xtreme 2.2
post #7 of 26 Old 03-28-2009, 10:26 PM
jtcfanof3's Avatar
I stand a little corrected,a shorter spring makes for a stiffer ride,unless its thinner.BUt stock springs are designed with the thickness for a specific spring rate,drop coils are made with a diffrent spring rate which allows for a stiffer ride but less chance of bottoming out.
post #8 of 26 Old 03-28-2009, 10:56 PM
david gmc's Avatar
User is: david gmc is offline
drop spindles dont cost much and they are ALOT safer than cutting the springs
post #9 of 26 Old 03-28-2009, 11:02 PM Thread Starter
kylers2k's Avatar
4" blocks at the rear the way to go?
kylers2k is offline
post #10 of 26 Old 03-29-2009, 12:24 AM
Freedom
I thought you said in your first post that you already dropped the S10?
Cutting the spring is bad because the spring doesn't allow for the shorter travel distance with a stiffer spring rate. Also, by cutting your spring you run the high risk of not cutting both springs the exact same amount, which would therefore cause it not to drive/ride correctly. Either one of these could cause you to lose control and hurt/kill yourself and/or others. As far as the back is concerned...you can't flip the spring. I don't know how flipping a spring would be possible on ANY leaf spring vehicle, but whatever. Anyway, taking a spring out would lower it a small amount, but you would have to know what you are doing to a T...you wouldn't want those ****ers coming apart on you while driving. Also, don't let anyone tell you that you can just mono leaf it, because that is a worse idea than cutting your coils in the front. Yes, you can go with 4" drop blocks if you want. That would be probably you're cheapest bet, but still not the "best." I say this only because of how the drop block/leaf spring/axel react with regards to each other under load and high stress situations such as strong launches. If you need that explained, feel free to ask. I don't mind explaining that, but I don't want to type it all if I don't need to. You know? You're safest bet would be to go with 3" drop leaf springs and then a 1" drop block if a total of 4" is what you are after. But, a 4" block will work if that's what you want.
What are the specs on the truck? Year? Extended cab? Short bed? What are you working on, basically?
post #11 of 26 Old 03-29-2009, 01:07 AM Thread Starter
kylers2k's Avatar
92 single cab short bed and no its not dropped
kylers2k is offline
post #12 of 26 Old 03-29-2009, 01:12 AM
Freedom
Okay...you're cheapest way to lower, that is still relatively safe, would be to get some drop coils for the front and drop blocks for the back. I would recommend replacing your shocks with drop shocks while you're at it. Also, if you're going to drop the back at least 4" then I would recommend cutting the bumpstop and the bumpstop bracket out. I had my 2000 lowered 4 in the back and it was constantly bottoming out. Removing the bumpstop gave me a better ride but it would still bottom out if if I hit a pothole or something to hard. Removing the whole bracket fixed that problem.
post #13 of 26 Old 03-29-2009, 01:15 AM
Freedom
post #14 of 26 Old 03-29-2009, 01:16 AM
Old School Baggin AGAIN!!
88sdime's Avatar
User is: 88sdime is offline
Send a message via AIM to 88sdime Send a message via Yahoo to 88sdime
this is the best way... drop coils and blocks are cheap and you'll get a 3/4 drop out of it. deffinately do the drop shocks though. then if you want later on you can add the spindles and the leafs for a total of 5/7 drop. its the exact way i dropped mine 4 years ago.
88sdime is offline
post #15 of 26 Old 03-29-2009, 01:21 AM Thread Starter
kylers2k's Avatar
thanks guys
just tryin to get it done cheap as i dont wanna throw too much money into it anymore
got a silverado to mess around with for awhile now
kylers2k is offline
post #16 of 26 Old 03-29-2009, 01:22 AM
Freedom
Exactly.
Originally Posted by kylers2k View Post
thanks guys
kylers2K, don't be like some of the people that come on here and ask for a "cheap way to lower" and then don't take people's advice when they tell you not to cut springs or anything like that. Do it right and do it safely. Sure, the other ways are cheaper, but they are at a risk to you and everyone else on the road.
I understand wanting to do it as cheap as you can...I'm married with a kid...but like I said, do it so you don't endanger anyone.
post #17 of 26 Old 03-29-2009, 01:24 AM Thread Starter
kylers2k's Avatar
yeah i definetly wont cut the springs like a friend told me to do..
ill get drop coils, 4" blocks and drop shocks and remove the bumpstops and brackets.. i read up on that earlier..
that should be pretty cheap and be a not toooooo bad ride .. and look good
kylers2k is offline
post #18 of 26 Old 03-29-2009, 01:32 AM
Freedom
I had 2" dropcoils in front and out back I had 3" leafs and a 1" block. I rode like that for 4 years with no problems. The ride was rough until I cut out the bracket in the back, but other than that it was fine.
post #19 of 26 Old 03-29-2009, 09:26 PM
92awdtsi's Avatar
User is: 92awdtsi is offline
yea just spend the money and do it right the first time. i just got done lowering my 88. 2" spindles, 3" coils, 3" leafs, 3" angled blocks, drop shocks all around... ended up costing me just over 500 bucks including shipping. ebay is great.
92awdtsi is offline
post #20 of 26 Old 03-31-2009, 10:03 PM
sleeper
slpns10's Avatar
User is: slpns10 is offline
the only way to lose controll is if you really suck at driving my buddy had a 91 blazer and we cut the srings in the front to get a 3 inch drop and then made blocks and stole some ubolts and shit and that was the shittyest ride ever but it looked good tho
slpns10 is offline
post #21 of 26 Old 04-01-2009, 11:36 AM
Freedom
Yeah...YOU sound like someone to take lowering advice from.
post #22 of 26 Old 04-01-2009, 12:47 PM
gearhead420_24-7's Avatar
User is: gearhead420_24-7 is offline
ive cut springs in the past and didnt have any issues. i run 3in. belltech spring with belltech shocks on both my current trucks and love the ride.
never recommend heating springs but i have done it for buddies that didnt want to remove the springs to cut em or replace them. i wouldnt ever do it to mine but they were happy with it and didnt have any issues either.
98 4.3 5 speed,electric fan,cold air intake,flowmaster,rollpan,flush bedcover,cowl hood,carbonfiber tails,clear turnsignal,xenon front bumper,buckets,grant steering wheel,18",belltech.
88 2.8 5 speed,throtlebody spacer,electric fan,k&n,dynamax,rollpan,cowl hood,92 core support & grill,carbonfiber tails,clear corners & bumpers,racing seats,grant steering wheel,ss mirrors,17",belltech.
Bravada Grills Suck Coalition
post #23 of 26 Old 04-01-2009, 01:03 PM
sexysonomaowner08's Avatar
User is: sexysonomaowner08 is offline
Too bad you dont live in cali. There is a shop right down the street from my house that would get you some drop spindals, install them, and make sure everything is safe like rotating tires and all that good stuff, and they will do it for 100bucks out the door. That includes the install
post #24 of 26 Old 04-01-2009, 08:25 PM
sleeper
slpns10's Avatar
my buddy bought 2" spindles and 3" springs and 3"lowering springs and 2" blocks we only cut the springs a week b4 he bought all the right stuff we were just messin around.
slpns10 is offline
post #25 of 26 Old 04-02-2009, 01:27 AM
baby blue
Licenseplate's Avatar
User is: Licenseplate is offline
the best way to do it is the right way
if you want low, you could get 3" block and zq8 leafs (or drop leafs)
coils and spindles to give 4 or 5" drop
would be about $500 depending on the deals you can manage, may be more
post #26 of 26 Old 07-31-2012, 09:32 AM
User is: chancellor is offline
do they make drop shackles for a 92 ?
