bars leak? - S-10 Forum
post #1 of 10 Old 06-15-2012, 04:44 PM Thread Starter
ahalfacre5's Avatar
User is: ahalfacre5 is offline
bars leak?
so.. i know im going to get crap for this BUT, im lazy.
I have a small oil leak out of my distributor rod, and i wanted to know if i added the silver bottle of bars leak engine oil would hurt. I've heard it helps, heard it hurts, and heard it does nothing... i already have it but wanted to check first.. thanks guys
GMC S15 GYPSY 2.8L 4x4 Auto - R.I.P
1987 BMW 325is (e30ftw) - weekend warrior/project - sold
1996 Chevy Blazer ls 4x4, 3in shackles torsion bar tweak, 1.5in body lift, 1200watt soundstorm amp, infinity kappa 12.1 sub, 4.3 crate engine
1982 Honda GL500 cafe racer
post #2 of 10 Old 06-15-2012, 04:53 PM
Cruisin' old school.. '82
jedgell233's Avatar
User is: jedgell233 is offline
Re: bars leak?
I've never used the stuff myself. Though I've heard many reviews in the past that the stuff does work but only temporarily. Which makes sense cause its suppose to be a temp fix til you can get the actual problem fixed.
1982 Chevy S10 2WD
________________________
2.8L 2BBL Rochester Varajet II 2SE
4spd Manual Transmission (Cable Clutch)
Short Bed
Regular Cab
Somewhat "Painfully Stock"
post #3 of 10 Old 06-15-2012, 06:44 PM
User is: bg's is offline
Re: bars leak?
There is a gasket that sits between the dist and the intake manifold.
Pull the dist out after marking it's location, rotor location, etc, replace
the gasket and be done with it. Don't put snake oil is a good running
engine because of a failed gasket.
If this stuff was so good, MFG's would use it instead of gaskets..
bg's is offline
post #4 of 10 Old 06-16-2012, 11:18 AM
ASE certified MasterTech
jtcfanof3's Avatar
User is: jtcfanof3 is offline
Send a message via AIM to jtcfanof3
Re: bars leak?
Save yourself the future problems and dont use it, just fix it right the first time, as said replace the round base gasket below the distributor.
1989 Chevrolet Blazer 3.4
1989 Chevrolet Blazer 4.3 4x4
1989 Chevrolet Blazer 4.3 Edelbrock equipped
2003 Chevrolet S10 4.3
1999 Chevrolet S10 Xtreme 2.2
post #5 of 10 Old 06-16-2012, 11:43 AM
Registered Hoosier
Hoosier Rick's Avatar
Re: bars leak?
If it is the truck in your sig, they have an oring instead of a gasket. I would replace the oring, and also add a small block dist gasket.
2000 Jimmy 4x4 4dr. 252,000 miles
2002 rcsb, 2.2 at, 253,000 miles
1967 C10
post #6 of 10 Old 06-24-2012, 11:25 AM
Jim_Rockford's Avatar
User is: Jim_Rockford is offline
Re: bars leak?
DO NOT USE...AT ALL ,don't even look at the bottle.
post #7 of 10 Old 06-25-2012, 07:31 PM
User is: zarmo24 is offline
Re: bars leak?
That's funny...don't use it...I had a wee small external coolant leak at the back right corner of the head on my 89 Supra and when I discovered it I was 600 miles from home. I tossed in a can of Bars Leak hoping at least to make it back home without having to replace the head gasket. Three years later (still no leak) I sold the car. JMOE
zarmo24 is offline
post #8 of 10 Old 06-25-2012, 09:14 PM
Fronk-en-Steen
mostizzle's Avatar
User is: mostizzle is offline
Re: bars leak?
Cool story bro.
TelAmeriCorp
post #9 of 10 Old 06-26-2012, 12:29 AM
Re: bars leak?
post #10 of 10 Old 06-26-2012, 01:40 AM
User is: ranman is offline
Re: bars leak?
I know oil is a coolant too, and so is... um....."coolant"
The guy said he has a an oil leak.
Then you said that Bars Leak fixed your coolant problem for years................ but you said not to use it, even tho it works.
I is scratchin my head here.
To the original poster............ replace the gasket. Sealer in a bottle is a last resort attempt for those ugly, more difficult, and more expensive fixes like timing and rear main seals.
They can and sometimes do work............. but they are not the best option. If a leak occurs, the seal has turned to crap and needs to be replaced.
Sealer in a bottle for your fix, may cause the rear seal and the timing cover seal to start leaking, since oil sealers soften the seals.
If you fix and easy sealing repair by using a bottle because you are lazy
(your words, not mine )
... and end up causing other, more major seals to leak.
....... then what will be the moral of the story?
ranman is offline
