ABS code 10
Old 07-17-2008, 11:19 PM   #1
adamwilkes20's Avatar
adamwilkes20 is on a distinguished road
ABS code 10
Okay, my speedometer or odometer havent worked since I bought my truck...every once in a while my brake light will blink in this pattern...one long blink then 9 short blinks....from what I have read on here it is a high VSS output or something??? So, if I get a new VSS, should this stop? Will my speedo and odo begin to work again?
FYI...it is a 1991 Tahoe, 2.8L, 5spd
Old 07-20-2008, 02:27 AM   #2
Registered Minitrucker
hac327's Avatar
hac327 is on a distinguished road
Re: ABS code 10
flush your brake system
Old 07-20-2008, 10:30 AM   #3
Fan of the S-10
jtcfanof3's Avatar
jtcfanof3 is on a distinguished road
Re: ABS code 10
CHeck the 15A brake fuse in the fuse block first.
The ABS light blinking has nothing to do with the VSS,most likely your ABS module is bad,just un plug it,its only RWABS anyway!
I can look the ABS code 10 up for ya.
Old 07-21-2008, 04:31 PM   #4
Re: ABS code 10
okay, I checked the fuse and it was not blown, When I pulled it and started the truck, the brake light just stayed on and didnt blink. So are you saying just unplug the module???
Page generated in 0.07537 seconds with 11 queries
