Would it be worth the money if i put in A/C in to my truck which does not have A/C? And Would it be hard to?
Re: A/C question
I'm not sure but I believe it would be a pita. Just have removable sunroof installed
Re: A/C question
Ya i was thinking of that to.
R/C Guru
Re: A/C question
I dont think it would be that much of a problem. Your just going to need to get a hold of all the correct parts. I would try to find a truck you can grab things like the blower box, all the wiring and the HVAC controls in the cab at the least. The rest of the parts you can probably obtain at your local parts place but they will be pricey, so a truck that has it all in good working order is your best bet.
My truck came with an aftermarket system installed in it which was a huge POS and whoever installed it did a horrible job and now Im missing over half the hardware in the dash because they didnt put it all back in.... Hope this helps, good luck. |
doing it for mom
Re: A/C question
How hard depends on your skill level. If your asking about a/c then its worth it to install it. A wrecker should know what you need and when you ask for a change over they will pull all you need to do it. (or at least should) I did this in my mom's first S10 and they forgot to give me the door under the cowl panel and the resivour ball. All I did was tell them and they got it for me.
Re: A/C question
Ya i got this week off practically so i will go to some of the local junkyards and look for some A/C Parts
Re: A/C question
If you don't have power steering the you will need the pulleys for the belts to line up. i just completed this, ill post pics when i get home.
Re: A/C question
ya i have power steering
Re: A/C question
![]() ![]() That my install, i had to move the alternator down where the air pump was, and use a turn buckle for the top bracket. |
Re: A/C question
what year is that truck?
Re: A/C question
I Rather Be Wheelin'
Re: A/C question
I want to put A/C in my truck.
Removable sunroofs are over-rated & complete trash. |
