92 S10 pickup 4x4 motor mount replacement help - S-10 Forum
post #1 of 3 Old 12-23-2007, 10:55 PM Thread Starter
User is: torque_addict is offline
I am trying to replace my motor mounts on my 92 4.3 4x4 5 speed S10 pickup but I can't get enough clearance to get the bolts off. How is this normally done?
Books say to jack the engine and just unbolt the mount- although the factory manual says to lift the cab or body but I don't know how or if it's needed (book doesn't say)
I removed the "pin" bolt on both sides but I can't raise the engine enough to get a socket to remove the center bolt on the mount and I can't remove the frame bracket since I can't reach all the nuts to keep then from turning.
What's the normal way this is done? Shops want $400 for this job.
thanks in advance for any tips!
post #2 of 3 Old 12-24-2007, 02:39 PM
HappyBuddaBelly's Avatar
User is: HappyBuddaBelly is offline
Re: 92 S10 pickup 4x4 motor mount replacement help
It's normally done by unbolting the radiator support from the chassis and if necessary the front of the cab, having an engine hoist lifting up on the engine, and a set of very small hands.
'91 Sonoma ST
Rust Bucket
3.42 rear end
so many plans
If you live in the Indianapolis Metro area, I'm available for helping with all sorts of projects, especially heavy parts lifting, like transmission jobs without the jack.
post #3 of 3 Old 12-24-2007, 09:18 PM
User is: bg's is offline
If you do a search in the 262 forum under 4x4 motor mounts, you will get a number
of threads, etc..
bg's is offline
