91 S10 Fuel not spraying - S-10 Forum
post #1 of 9 Old 12-01-2011, 02:53 PM Thread Starter
User is: durr711 is offline
Hi I have a 91 S10 2.5 tbi and the injector is not getting a ground pulse. It has new ECU and ignition control module. You can manully ground it and pulse it yourself and it will run! Any ideas I am stumped? Also there is a gray wire all by itself I cant find where it goes that might be the problem. Here is a pic of the wire.
ID:	121347   Click image for larger version
durr711 is offline
post #2 of 9 Old 12-02-2011, 12:45 AM
2003Xtreme's Avatar
User is: 2003Xtreme is offline
Re: 91 S10 Fuel not spraying
I think the wire in your picture is a test point.. Like for a test light.. ground it and touch it there to make sure your light is grounded good. Not 100 positive, but I think I am close.. lol
99 Hugger Orange Z28
93 Suburban Lowered
91 S10 shortbed Lowered
Project Build Thread Links
http://www.s10forum.com/forum/f135/s...y-pics-483887/
http://www.s10forum.com/forum/f135/f...yard-d-483861/
http://www.s10forum.com/forum/f3/198...t-work-489962/
Originally Posted by J_SIN View Post
I'd rather pump up my bags with a bicycle pump than use their products.
post #3 of 9 Old 12-02-2011, 11:30 AM Thread Starter
Ok do you have any idea why it wont start?
durr711 is offline
post #4 of 9 Old 12-02-2011, 01:39 PM
ASE certified MasterTech
jtcfanof3's Avatar
User is: jtcfanof3 is offline
Send a message via AIM to jtcfanof3
That's the fuel pump test lead. Have you verified the circuit is good from the pick up coil to the ECM? And ECM to injector circuit?
1989 Chevrolet Blazer 3.4
1989 Chevrolet Blazer 4.3 4x4
1989 Chevrolet Blazer 4.3 Edelbrock equipped
2003 Chevrolet S10 4.3
1999 Chevrolet S10 Xtreme 2.2
post #5 of 9 Old 12-02-2011, 02:49 PM Thread Starter
The wire from the ecm to the injector is good. Which wire off the pick up coil is the one for the injector?
durr711 is offline
post #6 of 9 Old 12-03-2011, 09:01 AM
1st gen v8
00LS1TransAm's Avatar
User is: 00LS1TransAm is offline
Check the fuse for the ECM
02 ram 2500 -diesel 6 speed lifted on 35's
94 s10 -excabsb 4.3 5 speed c5 Z06's
post #7 of 9 Old 12-03-2011, 05:40 PM
Solid Axle MOD
Sonomanclature's Avatar
As stated that wire is the test lead fo the pump, the wire from the pickup coil is purple/white for high, and black/red for low. it is almost impossible to test iwth a multimeter. You can take the ICM which the pickup is located in, and have an auto parts store test it.
94 Sonoma Dana44/60 5.7L 5spd
06 Subaru Impreza
post #8 of 9 Old 12-03-2011, 06:57 PM
jtcfanof3's Avatar
You can test the circuit, continuity. Verify the circuit is good. And yes, have the ICM tested at a parts house. Did you verify the fuses were good yet?
If it is working you can also run a voltage drop test on the circuits with a meter...
post #9 of 9 Old 12-03-2011, 08:02 PM Thread Starter
I sold the truck just going to get another one didnt have any more money to put in it!
durr711 is offline
